Question about HP PSC 2110 Color Printer
How do you clean the nozzles without connecting to a computer
  • HP Master
  • 13,433 Answers
Probably the best solution is to use Magic Bullet to get it working like new again, have a look http://www.specialistinks.com/unblock-printer-heads.php
Posted on Oct 04, 2010
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
What are the steps to cleaning the print heads on the X1150 printer? New at this. Mike
On your computer, open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center) > From the Maintenance tab, click Clean to fix horizontal streaks > Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
Source: How to Resolve a Blurry Print Issue Without Replacing the Cartridge
May 07, 2011 | Lexmark X1150 All-In-One InkJet Printer
Cleaning nozzles without using a computer
Good day. Yes, it is possible to clean the nozzles of the cartridges using the buttons on the printer. Just follow these steps:
1. Load paper in the printer feeder.
2. Press Copy.
3. Press Options until Maintenance appears on the display.
4. Press the right arrow until Clean Cartridges appears on the display.
5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
To print a test page using the buttons, follow steps 1-3. Then, press the right arrow until Print a Test Page appears on the display. Press select.
Hope this helps.
Mar 16, 2010 | Lexmark X6170 All-In-One InkJet Printer
1999 ford focus estate diesel.Windscreen washer bottle has black mildew in it.how do i get it out as it blocks the washer jets.
Remove the windshield washer reservoir and give it a good cleaning with a mixture of 1 part bleach and 3 parts water. You may be able to clean it without removing the reservoir by flushing it throughly and the cleaning it while still on the vehicle with the bleach mix. After it is throughly cleaned put a bleach mix in the reservoir and disconnect the hoses from the spray nozzles and run the washer until the hoses are clean. Use a needle to clean out the nozzles, and the connect the hoses and run the washer until the nozzles are clear. Remove the bleach mix and then fill the reservoir with a commercial windshield washer fluid. I recommend Rain X.
Mar 07, 2010 | 2000 Ford Focus
Fan overheats need to know how to open computer to get to fan
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
Thats because there are hidden screws.
You also have to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
Oct 10, 2009 | HP Compaq Presario M2010US Notebook
Restart by itself while working
good guides here.
Take a
Oct 04, 2009 | HP Mini 1000 Netbook
On startup I get 'fan error' and it shuts down immediately
good guides here.
Take a
Oct 02, 2009 | IBM ThinkPad T30 2366 Notebook
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pictures on my Canon Pixma iP5000 are now printing all green! The magenta tank had been empty and I replaced it, but there has been no improvement.
Green ignorance. I could never find the print utility on my Mac but at last I found how to perform a nozzle clean without using the computer. Press the resume button on the pritner until the power light flashes once - and presto, it cleans the nozzle and the problem was solved.
Dec 03, 2008 | Office Equipment & Supplies
The RX500 prints only one color or two
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
Jun 28, 2008 | Epson Stylus RX500 All-In-One InkJet...
HP PSC 2110 Color Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
