Question about Kenmore Washing Machines
Kenmore elite quiet pak 2 110.45872404 F6 error message, what does this message mean?
  • 326 Answers
SOURCE: keep getting f2 signal on
F2 and F02 error are one and the same. My daughter was doing a load of towels in my Kenmore Elite HE3t front loading machine, when I went back to put them in the dryer the washer had a load of water in it and an error reading of F02. Checked the manual Could not find anything wrong with the Drain Hose?
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display.* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on May 06, 2009
  • 272 Answers
SOURCE: Error code F21 - thanks for your help
The F21 error code is an indication that the unit has too long of a drain out condition. If the control calls for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Clear pump of debris. Tilt machine. Take off front panel. Unscrew large white drain plug. Remove debris.
Unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. That will help get rid off the debris.
It can be done if you are patient and able to figure out how the plastic thing comes apart. Good luck!
Posted on May 09, 2009
SOURCE: I have quiet pak 2 kenmore elite. It will not
i have the same problem right now today hope some one knows how to fix it ,, have cleaned out bottom hoses and catch pan nothing ..
Posted on Feb 17, 2010
jsrock516
  • 5911 Answers
SOURCE: My Kenmore smartwash quiet pak 9 HE4T will not
"F6" is a Motor Speed error problem. It is commonly attributed to a broken or slipped drive belt, defective Drive Motor, or bad Motor Control Unit (MCU). The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Feb 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: F11 error code on a
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 08, 2010
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping...
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quiet pak 9 dryer
Error message E1 indicates the temperature thermistor has failed.
Jun 22, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
238 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
