I have a kenmore washer 11022642100. how do i remove the top cover
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
aborcass
  • 2651 Answers
SOURCE: washer top
HERES A LINK TO SHOW YOU HOW
Posted on Nov 06, 2008
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Posted on Jan 13, 2009
flatech
  • 111 Answers
SOURCE: Kenmore 70 Series washer need to know how to
Get yourself a screwdriver Philips.
Now there are two screws either at the front lower of the electrical switches or in the very back of the washer around the same panel.
Unscrew those screws and once they are loose then you should be able to pull the entire top electrical piece towards you.
Once you have this loose then get a flat headed screwdriver and pop out the two brackets that are attached to the top of the unit, under the controller peice you just removed
Next make sure to unplug the wire that is attached to the lid switch.
Once those are loose then you just simply pull the entire cover towards yourself and then you will have access to the area you want to be in.
Good Luck!
Posted on Nov 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: how to remove top from kenmore washer
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
Have a 110.22642100 Kenmore washing macihne that has a metal clang on the spin cycle that occurs every second or less. The tub does not rotate much. I replaced the motor coupling since it was split but is...
Hello Jye,
It does sound like either the clutch is bad or the Motor coupler is bad. I have included a video showing how to replace the coupler Kenmore Washing Machine Model 110 22642100 11022642100 110 22642100 Parts
The coupler is about $18 and the Clutch is about $48
Good Luck!
Rich Lilja
May 19, 2017 | Kenmore 22642 Top Load Washer
My kenmore 70 series washer will not spin or agitate
if you can hear the motor running,then its the direct drive coupler between the motor and transmission that the teeth are broken off and cannot mesh, you need to remove front panel to check,but,if no motor noise,then its your lid safety switch under the top cover,you need to remove front and top cover to check
Apr 11, 2011 | Kenmore 22422 Top Load Washer
It suddenly began leaking somewhere on the inside. This happened first when I was not around and not only did it leak from the bottom, the thing kept filling up and not stopping, resulting in a flood in...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022642100/0582/0153200?pathTaken=&prst=0&shdMod=11022642100
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Jan 25, 2011 | Kenmore 22642 Top Load Washer
How do i remove the cover
the top does not come off by itsself. you need to remove the control panel two screws on the back and possible two screws on the bottom corners and slide the panel forward. the remove the two clips that hold the case together with the back of the washer panel.then tilt the cabinet forward to remove it
Mar 14, 2010 | Kenmore 23822 Top Load Washer
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washing machine discharge,but will not spin
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
May 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
