Question about Cameras
DMC-ZS1 Upon turning on camera to take a picture - the camera tells me that the memory card is locked. The camera seems frozen.
  • 13,433 Answers
Remove the memory card from the camera, then turn it back on with out a memory card. does it work normally aside from very limited picture storage space?
On the side of the card there is a lock switch, make sure its not on the LOCK position, try the other position and insert it to the camera, if the card locked message comes again, move it to the other position and try again.
Now if the issue still remains, on the side of the lock switch, when you insert the card. inside the camera there is a small metal "hand" that gets pressed down if its on the locked position, this hand must have gotten stuck to the lock position and it would need to be pulled just a bit (1-2mm) so that it does not touch the metal.
DMC-ZS1
Posted on Oct 04, 2010
I have pictures in playback when my memory card is in camera and none without memory card in camera but when I put memory card into a card reader and put into my computer the pictures do not show up, I am...
What type and size memory card? Is your card reader compatible with the card?
If I had to take a guess, you're using an SDHC card (4GB or larger) while your card reader is only compatible with SD cards (2GB or smaller).
Dec 02, 2013 | Panasonic DMC-ZS1 Digital Camera
My DMC-Z51 will only write to internal memory and not to sd chip
You need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. After that, your memory card should work.
Oct 01, 2011 | Panasonic DMC-ZS1 Digital Camera
Hi, I took pictures with the memory card
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101=-
Aug 26, 2011 | Panasonic DMC-ZS1 Digital Camera
I have panasonic lumix DMC ZX1. when trying to take pictures it says pictures will be stored in inbuilt memory inspite sd card being inserted in right place and empty.
Welcome to FixYa.
Before using the memory card, it should be fromatted. Possible reason is memory card is not yet formatted for camera use.
*Note: Use the camera itself when formatiing the camera. Using PC's or another camera in formatting the memory card may cause a "CARD ERROR" message.
If the switch on the card is set to "LOCK"; operations such as formatting, recording and deleting cannot be performed.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 12, 2011 | Panasonic DMC-ZS1 Digital Camera
My camera(panasonic dmc-zs1) has apparently been damaged by static electricity. I did feel a static shock when i went to pick it up. It will turn on and off but will not respond to any of the buttons...
When electronic hardware take a static shock it scrambles the processor and locks most functions down. One possible solution is to remove the battery and the memory card and allow 30 minutes to get rid of any residual charge and allow the processor to reset. Replace the battery only at this point, now try your camera to see if it will operate, if all goes well load the card back in, if this fails it is more practical to replace the camera and cheaper in the long run.
Jan 28, 2011 | Panasonic DMC-ZS1 Digital Camera
I have a Panasonic Lumix DMC-ZS1. Once I transfer the media cards pictures onto the computer and then re-insert the card into the camera, all pictures seem to have been deleted. However, when I take the...
When you remove the card from the computer, do you use the "safely remove hardware" function? If you don't, the card can become corrupted enough that your camera no longer recognizes it.
Apr 26, 2010 | Panasonic DMC-ZS1 Digital Camera
I was taking pictures outside on a cold day and the camera froze - after warming it up I was able to take more pictures but I thought I lost all the previous ones. I subsequently took about 50 pictures and...
Could be a problem with the "no. reset" in the menu. I would go into the menu and find the regular "reset" and follow the on-screen instructions to get your camera back to factory settings. Then, format your card in the camera.
Feb 07, 2010 | Panasonic DMC-ZS1 Digital Camera
Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
Jan 19, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
CANT WRITE TO UNLOCKED SD CARD I've tried repeatedly to write files to various sd memory cards in my ZS1 and it always gives me the message that the card is locked and can't be written. The cards are...
Are you sure that the lock / unlock tab isn't getting moved to the lock position when inserted AND then moved back to the unlock position when removed? Stranger things have happened.
Some cards have lock / unlock tabs that are so flimsy that it seems that you can "will" them to move. Try placing a small amount of tape in such a way that the tab is prevented from moving (if you never use the lock feature like me, you could use a drop of glue instead of tape). You might have to remove some excess tape in order to slip it back into the camera if the slot is "tight".
If still unable to write to the card in the camera, but can when in a card reader - the problem could be in the camera. The next logical step would be to try a different card. If the new card fails in the camera but not the card reader; the camera probably needs to be sent out for repair.
I hope this helps - and good luck!
Nov 13, 2009 | Panasonic DMC-ZS1 Digital Camera
Frozen Camera
Try letting it drop about 4 tto 6 inches on a hard service covered by a paper towel. Don't let it land on lens of course. You can remove the mem card. It has 13Meg of internal.
Mar 22, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
