Question about Roland MA 8 Computer Speakers
I want to mount B-Tech BT1 wall brackets on my Roland MA-8 speakers. I am thinking of using 1/2" #6 or #8 sheet metal screws. My questions are these: (1) will the wall brackets be enough to hold the speakers, especially the one with the amplifier inside; and, (2) will I hit anything inside when the screw goes into the back of the plastic speaker cabinet.
  • 8,197 Answers
As for ? 1. The brackets will be strong enough to hold the speakers up. ? 2. If you attach the brackets towards the top of the speaker you will not hit the amp inside. Sense you are using just half inch screws you are safe. I would use the #6 screws.
Good Luck and please accept the answer
Posted on Oct 04, 2010
  • Jyackle5
    Jyackle5 Oct 10, 2010
    Would like to know if you got the speakers hung. If not I will still help you
How to install hansgrohe toilet brush
This model has a bracket that will mount to the wall using two screws and plastic anchors. Then the brush holder will snap into place on this bracket. There will be a hole in the bottom of the holder that will look like a set screw but this is only a push pin. It is spring activated and not threaded. To remove it you simply push up on this pin and pull the holer off the wall bracket. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for Tech and Ask for David Scarborough. I'll be happy to help.
Nov 20, 2012 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
How do I replace speakers on a 1994 xj6 ?
Replacement of Front and Rear Door Speakers
Required Tools:
#2 Phillips Screwdriver (magnetic tip is useful)
9 mm Nut Driver
8” or 10” Flat Tip Screwdriver
Small awl or other sharp pointed instrument
Soldering Iron w/solder or 8 to 10 small wire **** splices
8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
Thread locking compound “Loctite” (optional)
6” wooden dowel of ½” diameter to be used as a drift
Small mallet or hammer
1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
3) Remove the Upper Inner Door Panels as follows:
It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
4) Remove the Lower Inner Door Panels as follows:
a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
5) Remove Door Mounted Speaker as follows:
a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
6) Install New Door Mounted Speaker as follows:
Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
8) Perform Steps 3 through 6 for the other doors and the job is complete.
9) Remove Rear Footwell Mounted Speaker as follows:
This sequence is good for both 4” and 5.25” footwell mounted woofers.
a) Using a small flat screwdriver as a lever, carefully ease off the grill.
b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
c) Ease out the old speaker and release the electrical connector for the speaker wires.
d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
e) Re-connect the speaker wires to the harness by joining the electrical connector.
f) Mount the new speaker and re-attach the necessary sheet metal screws.
g) Press the speaker grill into place.
h) Repeat Steps 9a though 9g for the other footwell speaker.
Mar 10, 2010 | 1994 Jaguar XJ6
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What screw holes are used for wall mounting a Sylvania 37 in LCD
the tv only weighs 55 lbs yes those are the holes 4 of them your bracket may have other screws if the bracket is thick
Mar 15, 2009 | Sylvania LD370SS8 37 in. LCD Television
Dayton SB36 wall mount question
Only you have the answer. Is there enough adjustment if you mounted on your wall specs? If not absolutely no!!!!! To support the weight, you must be in the stud.
But a question. Is this an interior or exterior wall. If you house is made of concrete block, the exterior wall only has 1x2 studs. The interior studs are usually framed by 2x4 (1.5x 3.5 in reality). Some houses use aluminum studes which I personally would not use.
If you are on an exterior wall, you couldn't use wood screws anyway. I would suggest using the appropriate TapCon. A screw made for concrete. An appropriate lenght might be 2 1/2 to 3 inches. This depends on sheetrock (1/2 or 3/4 inch) the depth of the bracket (you need to measure). To find the sheetrock depth simply take the cover off an AC receptacle. See if you some how measure the entire distance to the actual outside wall (stick a skewer along side the box till you make contact). Add 1 1/2" for the concrete, whatever your bracket depth is (at the point were screws go) and viola, you have the proper length of the screw. To size the screw, use the larget that your bracket can take (usually a #10 or 12). Definately pre-drill using the right size bit.
Hope this helps.
Jeff
Dec 21, 2007 | Audio Players & Recorders
Roland MA 8 Computer Speakers Logo
69 people viewed this question
Top Roland Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Joseph Mueller
Joseph Mueller
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
