Question about Whirlpool 4Foot 3Wire 30Amp Dryer Cord
Question:if you have 4 wire leads on power cord(a black, awhite, a red, and a green) , and only three base screws,where does the green lead go?
    Sergeant:
    Champion:
  • 351 Answers
Goes black white red green goes to cabinet
Posted on Oct 04, 2010
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
Trying to wire a four wire power cord to a washer dryer stackable that only has three bolts to wire to
Green Wire hooks Screws into the case of the machine (Ground wire)
Red and black are powers wires and they go on the left and right screws. And the white wire is neutral which goes on the middle screw. Hope this helps.
Green to case, Red, White, Black
Apr 09, 2012 | Dryers
I am replacing an old SS5 timer with this new one (ST01C) to control two sconces in my dining room. My question relates to the wiring. My old timer has three leads. The new one has four. In the switch...
Open following link to see clear drawing and instructions for wiring ST01C timer.
Page also has EZ programming steps:
http://waterheatertimer.org/ST01C-program.html#ST01C
Red wire is capped.
Blue wire goes to Load (wire to sconces)
Black wire connects to Line wire (wire from breaker)
Green wire goes to ground.
If you are uncertain about Load and Line wires, just connect them either way, turn power ON, push on-off button, it lights don't come on, then reverse wires.
I have tested this timer, and information here is correct.
Don't forget to install CR2 battery, otherwise display will not show.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I have a three way switch in a lamp, one red wire one black wire and one blue wire coming out off the switch,how do I wire off the switch?
Black is the AC power into the switch, and the others are the switched power leads out. Take a close look at the switch housing and you might see small markings reading L1 and L2 by the red and blue leads.
To wire the switch, use a pressure connector (wire nut) to connect the black lead to the incoming AC power. On a polarized line cord, where the plug has one prong wider than the other, the hot side is the narrow prong. The neutral side, which connects to the white wires from the lamp sockets, is the wide prong, and the cord usually has a ridge molded in.
The red and blue wires go to the sockets. (This kind of switch is usually used in three-socket lamps, so I assume that's what you have.) The red lead should connect to the black wire from one socket, and the blue lead to the black wires from the other two. The usual sequence is power off, L1 (red) on, L2 (blue) on, L1 and L2 on. So as you turn the switch (or press the button in a push switch) you get one light, then two, then all 3 on.
Make sure all your connections are good and tight with UL approved connectors and there are no exposed bare wires, and you should be good to go.
Feb 17, 2010 | Kitchen Appliances - Others
How to hook up a ge dryer change from a THREE PRONG TO FOUR PRONG HOOK UP
Replace the old Three prong cord with a 4 prong.
White wire from 4 prong cord goes to the center terminal of the connector block. If there is a metallic strip on that terminal that goes to ground remove it from the terminal and bend it away from the terminal and down so it either touches the case or ends in thin air. Be sure it can't touch either of the outside terminals of the 3 terminal block.
Red and Black wires of cord go to outside terminals of the three terminal block. It makes no difference which one goes on which terminal but I usually attach them so the color of the cord wire matches the colors of the wires already on that terminal.
The last terminal is green and should be attached tightly to any screw of the case or any metal bracket attached to the case that it is long enough to reach as this is the ground. This lead protects you from electrocution if the dryer has an internal problem and should be tight to the case.
Sep 22, 2009 | Dryers
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 | Dryers
Changing 3 wire to 4 wire cord on dryer [electric type]
If you had a 3 wire system and need to adapt your drier to a 4 wire system.. here is how you do it.. Your 4 wire cord should have the following colored wire ends.. Red, Black, White and Green.. The red and black are the power leads and should be attached to the red and black terminals on the back of the drier.. The White wire is Neutral and should be terminated on the white terminal of the drier.. The green wire is Ground and should be attached to the nearest frame or chassis screw at the point of entry into the drier.. If you are using a metal cable clamp as part of a feedthru system to get the cord into the drier.. you can attach the green wire to one of the screws on that.. but that should be done only if you canot find a suitable frame ground screw near the terminal block.. Hope this helps...
Aug 30, 2008 | Dryers
A new Amana dryer was delivered and installed (from Lowe's) yesterday. I am the tenant. Landlord is away temporarily. The dryer shuts off after about five seconds. It's type DWJR-ELE, etc., 29" Any...
check for proper connections of the power cord, sounds like a nutral and hot wire reversed
nutral in the center, white
black and red to the outside
green to frame ground
this is if you are using a 4 wire cord
three wire cord
black to outside screw
red to outside screw
white to center screw
grey three wire cord
center lead to center screw
outside lead to outside screw on each side
May 16, 2008 | Amana Dryers
Whirlpool 4Foot 3Wire 30Amp Dryer Cord Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
