Question about Dryers
Dryer was working fine several hours ago, tried to start it again, heard a fraction of a sound< then nothing. the breaker had not been tripped either,I did check that. What could it be????? please help.
    Sergeant:
    Champion:
  • 351 Answers
Belt may have broken
Posted on Oct 04, 2010
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
My dryer's electronic display lights but motor won't start. When start button is pushed, display flashes and a ticking sound is heard. I took dryer to neighbor's house, plugged it in and it worked fine....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 23, 2010 | Dryers
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
