Question about Magic Chef Toaster Ovens
The oven had the power turne off and I can't get it to work the model # is exc691s
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Half oven is working microwave oven is not working
You can buy it from Sears for $52.00 or you can call 1-800-330-9707 and they will mail you one free.
Dec 31, 2013 | Apollo Half Time Convection - Microwave...
I have a faberware convention turbo-oven model 460/5 and need a replacement knob of the power turn-on. Does anybody know where I can get this replacement part?
Here is the contact info for Farberware: Electric Appliances
farberware-electric@saltonusa.com 1-800-233-9054
If that doesn't help then try this address that gives you a list of websites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Apr 08, 2011 | Farberware T490C 1500 Watts Toaster Oven...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Oster toaster oven 6293 won't turn on
Ask here, it seems they can get you every Oster manual as a PDF file.
Jun 04, 2009 | Oster 6290 Toaster Oven with Convection...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Timer switch on Dualit 89100 1500 Watts Toaster Oven does not work so oven cannot be used. Any advice?If you turn timer all the way to 120 minutes and hold it the light in the oven will go on but no heat.
The timer switch is likely bad. Small convection ovens are notorious for this problem and switches may be difficult to find. Try smallapplianceparts.com or search "small appliance parts" for a few places that sell parts. You will need the make and model # of your oven.
Feb 22, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Shark jet oven Euro ProX Manual
OK, go to http://www.euro-pro.com/europro/faqdetail.aspx?modelno=to160l for model TO160L toaster oven or, if that is not the model number of your oven, enter model number (should be on the back plate of your oven: turn it around) into the box at the top left of the screen displayed when you use the address listed above. Good luck! alex bau.
Aug 11, 2008 | Euro-Pro TO285 1500 Watts Toaster Oven...
Toaster Ovens Logo
Top Magic Chef Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Magic Chef Toaster Oven Expert? Answer questions, earn points and help others
