Question about Fisher Paykel EcoSmart GWL15
My Aquasmart WL80T65D washing machine, stopped during a spin cycle and started beeping every second with a red spanner light flashing. I followed the manuals instructions to turn the machine off for a minute and take the clothes out etc but no luck and now when I put it on wash it does not fill and if I put it on rinse or spin it sounds like it is trying to go but it can't pick speed up?? I just copied this because I have exactly the same problem. Each time I attempt to start a load now the spanner flashes along with lights 3, 4 and 8 (delicates, sheets, high efficiency). Appreciate any assistance you can give.
  • Fisher Master
  • 713 Answers
Hi just read your fault.Now from the information in your posting the lights that are on when the machine is beeping are the 3,4 and 8th lights.Now these lights are in a row of 8 lights and you started from the left.So from left to right the lights that are lit when the machine is beeping are 3,4,and 8.Is this correct?If it is correct then the fault on your machine is called COLD VALVE FAULT.The 3 reasons why this fault occurs is, 1st the wiring to the water valves is faulty,the 2nd is the cold water valve is faulty, or 3rd the control module is faulty.Have you or can you borrow an electrical test meter so I can help you narrow down which is causing the fault.Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 04, 2010
  • 5 more comments
  • bgrossi21 Oct 04, 2010
    Thanks for the reply.
    It is definitely the 3, 4, and 8 lights which are on.
    I don't have my own multimeter but i should be able to get one from work tomorrow and can carry out some tests after that.
    Thanks.
  • luisa_sgro Oct 05, 2010
    Hi just read your last posting.Please reply when you have the multimeter and I can guide you throe the steps on testing the machine.Looking forward to your reply.
  • bgrossi21 Oct 05, 2010
    I'm ready to go so if you could give me a few places to check and the expected readings I can go from there.
    Thanks
  • luisa_sgro Oct 07, 2010
    Hi just read your posting.1st remove the 2 screws holding the top panel and gently lift the top panel away from the machine as the display board wiring is still attached.Put the panel on the lid.Now you should see to the right of the brown module the water valves.Have you got 5 coils or 2 coils?There will be a coil that is open circuit.Please reply on the number of coils you have and then we will go to the stage of testing them.Sorry for taking so long to get back to you.Looking forward to your reply.
  • bgrossi21 Oct 07, 2010
    OK. Took the panel off and found I have the brown module and 4 coils .... 2 Directly at the hot and cold inputs and 2 more behind them.
    Disconnected the inputs to each coil and measured the resistance to each and they were all the same .. around 58 ohms ...
  • luisa_sgro Oct 09, 2010
    Hi just read your last posting.Sorry it has taken a little while to get back to you but my computer was down again.Now if you measured all the coils and they were all at 58 ohms then as I mentioned in my 2nd posting the fault is more likely your control module.How do the wires to the coils like?Are they damaged? Can your local FISHER@PAYKEL dealer suggest anyone in your area that can test the control module for you. Do you live in Australia?If you do then there is a couple of places that will test and repair the module for you.And if there is nothing wrong with the module it does not cost much to test it.Then you will know if the module is the faulty component.Please reply if you would like the phone numbers of the places in Australia.What city are you in?Please reply with additional information and I will be looking out for your posting.
What is error code 49
Posted on Apr 10, 2011
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Washing machine filled with water but wont start, the spanner, delicates sheets and high efficiency lights come on after about 30 seconds, what could i look for
Fisher& Paykel have a lot of controls. But if it's filled with water and the lights are on, you have power to the unit. Try unplugging it, waif 5 min. Power it up advance the setting to drain/ spin setting with the door closed and try it again. What do you mean the spanner ?
May 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Simpson deluxe 526 stops at beginning of deep rinse cycle
fisher and paykel aquasmart model no. wl80t65d serial no.lyn686144
Aug 13, 2013 | Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
What's your problem?hello i have a auqa smart washing machine WL80T65D and the service spanner comings up beeping continously. At the same time the sheet, delecate, and hight efficency buttons li
That is fault code 49,
But in AquaSmart machines the pump has shorted mosfets on the board and caused this to blow the fuse that controls the water valves.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
May 14, 2012 | Fisher and Paykel Washing Machines
Pride 5.5 washing machine. Our washing machine stopped (during one of the wash cycles I think) and started to give a single beep every second and all the wash lights were illuminated.
Hi just read your posting.Can you advance the machine to a spin cycle?Or are all the controls frozen?Try advancing the machine to a spin cycle and push start then reply back and let me know what the machine does.Looking forward to your reply.Sounds like a lid switch fault.
May 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Aquasmart WL80T65D washing machine is telling me that it cannot lock the lid - but it is shut and appears to be in place.\r\n Does anyone have any suggestions for this?
Hi just read your posting.Does the machine stop and beep and show an error code in the form of lights on or an error code in an LCD display?Please reply with additional information and I am sure I can help you rectify the fault.Looking forward to your reply.
Oct 10, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
1,184 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
