Question about Makita & 1/2 Inch Drill
I have a Makita HP1621f Drill,and I cannot get the drill bit out,seems like the chuck itself is bad,any ideas on how to remove the drill bit?
  • 760 Answers
Sometimes if you happen to have the right size bit, it will stick into the bolt that holds the chuck on if the chuck wasn't tight enought to keep it from slipping further into the chuck. Clamp drill bit in vice and tap chuck with soft hammer to pull it free.
Posted on Oct 04, 2010
How to remove chuck from Makita hammer drill
Here's the info from Makita to repair / replace parts on this drill. This page displays a .pdf document and to read it correctly, you'll need to have the free Adobe Reader installed on your computer. The information you need can be found on page "3 / 12" Good luck!
Jul 08, 2013 | Drills
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Feb 12, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita & 1/2 Inch Drill  Logo
564 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
