Question about Primera Technology Signature Z6 InkJet Printer
Z6 printer does eveything to print a disc but no ink floes
  • Primera Tech... Master
  • 13,433 Answers
Hi
Either the ink cartridges are dried up, empty, or then the nozzles are clogged up - dried of ink blocking its passage onto the disc.
Try performing a print head cleaning from the computer.
If the cartridges are empty replace them.
If you haven't used this in a while and its been sitting around, either the ink in the cartridges is dried or then there is dried ink on the nozzels / ink path.
There is a product called magic bullet that might solve this problem, but since this is a CD/DVD printer, I'm not completely sure if this product works with your machine, have a look
http://www.specialistinks.com/unblock-printer-heads.php
they have a great video on the site that shows how to use the product and how it works. -- this might be your issue.
Posted on Oct 04, 2010
Document stuck in queqeu cannot print tried changing line tried on off. help c4280
If you are using it witha computer you need to go to the printer section and delete all the documents from the print queue.
Mar 15, 2015 | HP Photosmart C4280 All-in-One InkJet...
We print disc label and the discs need 10 minutes to dry!!!! Is there a way to solve the issue?
The only way to try to avoid this is with trial and error. You can adjust the amount of ink printed on the disk and the drying time in the software options but I can't guarantee you will be happy with the results. If adjusting the ink volume the printed image could become to lighter but it would dry faster. You will have to test some the settings and see the results for yourself.
Here's the steps from the manual to make the modifications:
Adjust the Ink Volume Used This functionality allows you to adjust the amount of ink that is used. 1. Navigate to Printing Preferences. (see below if unsure where to find) 2. Select the Basics tab. 3. Select Advanced Features. The Advanced Features window opens. 4. Move the Ink Volume and Dry Time sliders to increase or decrease the ink volume or dry time. - Important! Do not select the Low Memory checkbox unless your PC does not have enough memory or disk space to complete the print job you have requested. 5. Select OK. The Advanced Features window closes. 6. Select OK. The Preferences window closes
1. Access printing preferences. In Windows 2000, navigate: Start > Settings > Printers. In Windows XP, navigate: Start > Printers and Faxes. 2. Right-click on Disc Color Printer 480i and select Printing Preferences from the dropdown menu. The Disc Color Printer 480i Printing Preferences window opens.
Jul 15, 2011 | Rimage 480i inkjet printer
My printer will not print. the ink is brand new,
sounds to me like your inkjets are clogged get a q tip gently run a disc cleaner solution on them
Jun 14, 2009 | Lexmark X4270 All-In-One InkJet Printer
Install z615 lexmark printer with no disc
Hello markr,
You can download the full drivers by check those out:
Signature Z6 version 1.01 For Vista
Signature Pro version 1.20 For XP/2000
Signature Pro version 1.01 For Windows 98
Thanks for using FixYa.
Dec 23, 2008 | Primera Technology Signature Z6 InkJet...
Epson r265
Hi - What type of discs are you using? I have an Epson 200 series printer and use these discs click here.
Also what ink are you using as some "compatible" inks do not work well on printable discs.
Best regards,
Informatica
Jul 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Printer problems
Try to reset the device by turning the device off and unplugging it for a few minutes - then plug it back in and power back up. Sometimes being powered off will clear the jam sensors.
Jun 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
New ink went bad overnight
DancerTiffy,
I can't tell you why your machine is acting like that nor can I tell you that you have a problem.
What I can tell you is that you're not alone when it comes to the ink drying out all of the sudden. In the past few years I can't count the number of people who have explained this problem. I also can't count the number of people that have said their Epson produces the highest quality prints and their happy with it.
Your problem could be the printer or it could be the ink. Since it already happened twice it's hard to say.
  • How long have you had the machine?
  • Still under the retail store's return policy?
  • Still under the manufactures warranty?
  • Only two prints were printed?
May 30, 2008 | Epson Stylus RX580 InkJet Photo Printer
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Nov 29, 2007 | MicroBoards PF-2 InkJet Printer
Printer not printing
It sounds like it is out of ink. If you have replaced the ink cartridge recently, is it possible you forgot to remove the small piece of tape that is placed over the head to prevent ink leaks? That has to be removed before installation.
Aug 28, 2007 | HP DeskJet F380 All-In-One Printer
Primera Technology Signature Z6 InkJet Printer Logo
107 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Martyn01202
Martyn01202
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
