My mate came and took the bottom of the machine off and pulled a hair tie out. the machine is a intuitive eco and it says problem 76 i think if i remember correctly. I thought that if i take the bottom off and look for any blockage it will work again
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now,there is no error code that is numbered 76.Could you please confirm the error code and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 04, 2010
I've got Fisher and Paykel Excellence Top loader 7.5 My problem is, it won't unload or drain water. What do i have to do?
Hi, The washer wont unload or drain water until the drain pump is working. Get the pump off and look for debris. To remove the pump you unlock the tab and twist the pump a hair. The pump is on the bottom of tub.
Apr 13, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Which wire go where for F&P out of bamace sensor
white to the front of switch
yellow to the side
Hope thats clear Pieman
Jun 28, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher@paykel Intuitive eco comes up with code 130 what is it or how do we fix it
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Jun 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Service fault 130
Apr 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel intuitive eco
lean it back against the wall pump twist locks into bottom of tub..or pull the small plugs under each side of lid and remove the 2 phillips screws top lifts up
Jun 03, 2008 | Fisher Paykel Eco IWL16
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
