My Hornettek 1TB external hard drive has a fan that has recently started making a loud buzzing noise. Is the fan replaceable? Also is there a way to disable the fan without causing heating issues for the HD?
  • 148 Answers
Disabling the fan will cause heat issues , a replacement fan
fron the manufacturer or a universal from tiger direct
will work.
be sure no dust or debris is causing the noise first.
Posted on Oct 04, 2010
Testimonial: "Thanks for the information!"
    Filmmaker:
    Uploaded 5 video answers.
  • 109 Answers
Never disable the hard drive fan, however try to clean it and be sure that air can enter into it.
I advice you also to do a hard drive backup in case the problem persists.
http://harddriverestore.blogspot.com
Posted on Nov 10, 2010
Dell Dimension E520 Hard drive constantly buzzing
This could be a sign of a failing hard drive - I would backup all of your important documents immediately to an external drive to prevent you from losing any important data.
As you have already cleaned out the dust , there is a chance that one of the system fans (or the CPU fan) may be faulty or some wires inside your system case might be catching on the fan while it is spinning.
Disconnect all the system fans , so just the CPU fan is left plugged in and then switch on the system and see if the noise has stopped. Then plug each fan back in one at a time to identify if any of them are causing the noise.
Dec 01, 2013 | Dell Dimension E520 PC Desktop
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
No connection to WD hard drive
just change the usb cord the problem is in the usb
Mar 05, 2010 | Western Digital My Book Essential 1TB...
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Sep 25, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Computer noise
More likely one of the fans, but could be the hard drive. Open the case and listen. Fan on power supply, fan on processor, or hard drive are the most likely sources of the noise. Processor fans and power supplies are both cheap and easy to replace. Hard drive is a bit more expensive and you must back it up (which you already regularly do, right?) if you want to keep your data.
Apr 24, 2009 | E-Machines T3112 (RBT3112) PC Desktop
My computers hard drive makes a Buzzing noise
I would suggest you back up all your data as the hard drive appears to be failing. i presume you are certain it is coming from the hard drive and not a fan ?
Feb 21, 2009 | HP Computers & Internet
Intermittent buzzing noise
hmm..well..buzzing external drives are an accident waiting to happen. I'd get that puppy on the first jet across country..
you may want to back up your ext drive through this link
Mar 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
