Question about Sharp AL-1642CS Copier
H 4 flashing problem
Where are the buttons located that I should be pushing to try to clear the code?
  • Anonymous Sep 02, 2008
    AL 1631 KEEPS FLASHING H4/ WHERE IS RESET BUTTON?
  • 4 Answers
H4 flashing on Sharp copiers indicates that the fuser tempurature has failed to reach temperature in a given time. The posible causes of this are 1.Failure of the heater lamp or heater lamp drive circuit. 2. Failure of the temperature sensing circuit. 3. The initial temp. of the fuser roller was very cold. or 4.low mians supply voltage for a short time (brown out). The copier does not allow a simple on/off reset of this fault because in cause 2. above the copier may overheat and cause a fire.
The reset for this model should be:
Clear ® Density select ® Clear ® Density select - 14-Print.
Posted on May 29, 2008
The check engine light keeps coming on and off while i ride im smelling a burning smell what could be the problem ?
Beings the "Check Engine Light" goes off and on, there SHOULD be one or more error codes stored in the system.
Have you tried pulling any error codes?
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's.
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
If you DO get any error codes, repost them for diagnosis.
Jul 23, 2014 | 2006 Harley Davidson FLHR Road king
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox XC1020 Flashes code H 4
This should resolve your issue. If not it would most likely need a heat rod. But there ia probably a 99 percent chance this will cure it. Let me know please.
  9. Run a test copy.
Feb 16, 2009 | Xerox Office Equipment & Supplies
Code
UNDERNEATH THE TRAY WHERE THE PAPER COMES OUT THERE IS A ROTORY SWITCH WHICH IS CLEAR IN COLOR. IT IS EXTERNAL. IT MAY HAVE BEEN TURNED SLIGHTLY. IT IS SOME SORT OF LOCK, THAT IS WHY THE L IS FLASHING. IT IS RIGHT UNDER WHERE THE PAPER COMES OUT OF THE PRINTER. AFTER YOU TURN IT IN THE STRAIGHT POSITION, PUSH THE CLEAR BUTTON THEN THE BUTTON JUST LEFT OF THE CONTRAST ADJUSTMENT BUTTONS. DO THAT TWICE IN A ROW AND THE PRINTER WILL TURN OFF. PUSH CLEAR AGAIN AND IT WILL TURN IT BACK ON AND ALSO CLEAR THE TROUBLE CODE. GOOD LUCK.
Jan 15, 2009 | Toshiba e-STUDIO 150 All-In-One Laser...
Error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Dec 28, 2008 | Dishwashers
Clearing codes on liftmaster garage door opener with yellow learn button
you seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Flashing 4-H error message
fuser error - needs a tec - heater lamp, thermal fuse or thermister is broke. No simple fix
Oct 30, 2007 | Sharp AL 1631 Copier
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
