Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My dryer is not drying the clothes. I feel heat when I open the door though.
    Sergeant:
    Champion:
  • 351 Answers
Check vent maybe stopped up
Posted on Oct 04, 2010
  • 4 Answers
MAKE SURE YOUR AIR VENTING IS WORKING PROPERLY,STARTING FROM THE LINT FILTER TO THE DRYER
ITSELF SOMETIMES GETS PLUGED UP,TO WHERE IT GO'S TO THE OUTSIDE.
Dryer runs takes too long too dry clothes
Start the dryer and let it run for about 5-7 minutes, do you feel any heat if you open the door? If your dryer is producing heat most likely you have a restriction/blocked vent.
Oct 01, 2014 | Kenmore Dryers
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
My dryer will not dry clothes, I cleaned out the vent and hose, the tub is still moving, but when I open the door there is condensation and nothing is dry.
If you feel no heat from within the unit it may be possible that your heating element has gone bad (Electric).
Aug 23, 2009 | Kenmore Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer is not drying clothes
Go out to where the vent goes outdoors and feel if any air is blowing out of there with the dryer running. If you dont feel any air then probably your vent is blocked. You will need to clean it or fix the vent pipe if it is crushed.
May 12, 2009 | Dryers
Dryer not drying clothes
Check your heating element your lint trap and your exhaust hose.
You can check the element by opening the door pushing in on the switch and turn it on,you will feel or see the heat.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 18, 2009 | Maytag Performa PAV2200
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
