Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Installed a new 625 today replacing any old 510 receiver. On the new 625 I cannot get TV2 to record--can only get TV1 to record. Have called Dish and was told to put in a DP separator. My husband did that and we ended up with a receiver error.
    Novelist:
  • 185 Answers
Hello! Dan Busa with Dish Network here. I know you've probably gotten this up and running by now but just for reference to anyone on this site. Any cabling or connectors used to carry signal to the receiver should be rated for 2,150 mhz if this is not the case you will typically get signal loss messages.
Posted on Jan 06, 2011
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions Michael.houston@dishnetwork.com.
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
I am setting up the programs I want to record but it keeps sending the recording to TV1 which is the tuner my wife usually tunes into. How can I select TV2 for what I want to record ahead in time? It looks...
You can change the preference that you have set up and have it record to TV2. Go to Menu, then 8 - Preferences, and 5 - Record Plus. Change it to enabled, if not already, and TV2 for preference.
Nick Franta
DISH Network Customer Service
Jan 30, 2011 | DISH Network DVR-625 DTV Receiver /...
With 2 tvs you set to record on 1 and it records on 2 instead?records on the opposite tv
Hello, Matthew Gonzales with DISH Network here. The default setting in our receivers are to automatically record everything onto TV2. You can change the setting by pressing menu-8- 5 (preferences-record plus), then you can either disable the feature, or set it to record onto TV1. If the feature is disabled, the show will record at whichever TV the timer is set up on. If it is set to TV1, all timers will attempt to record on TV1 (unless TV1 already has a recording going on it then it goes to TV2). Hope this helps.
Matt
Jan 04, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a dvr 625 every so often while watching tv1 or tv2 it freezes up and all i can do is go over to the box and push and hold the power button to reset the box to get it working again. dish is trying to...
Press menu-6-1-3. Now select details and scroll all the way to the end. If any value has a number greater than a single digit the box will definitely need to be replaced. I can not explain why the issue would have started after the smart card was installed other than coincidence.
I hope this assists you and thanks for using Fix Ya.
Jun 19, 2010 | DISH Network DVR-625 DTV Receiver /...
I hav a duodvr 625 but its olny working for one tv how do i get it to show up on the other tv?
I will assume it was installed to two rooms when installed otherwise it will need to be wired to the second TV.
If it was indeed installed to two TVs at the first tv location with the TV1 remote press MENU-6-1-5. You should now be at the modulator set up screen. Note what channel TV2 is modulated to generally 60 air or 73 cable.
Now go to the TV2 location and run a cannel search. If it does not find the channel go back to tv 1 and change the TV channel to the opposite setting of air or cable based on what it was previously set to and try the channel scan at TV2 again.
If it still does not pick it up then most likely it is not wired for that room.
If the receiver was installed to one location Dish will need to wire the second location for you in order to achieve the desired outcome.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 24, 2010 | DISH Network DVR-625 DTV Receiver /...
Dish dvr 625 can't get dvd/vcr player to work with tv2..
if you have the coax hooked to the VCR in you will need to change the VCR channel to 22 and leave the TV itself tuned to 3 or 4.. I recommend setting the vcr to 60 or 73 to see if you can get reception on there as that is usually the two channels that TV2 is modulated on. You can check the modulation by going to TV1 and pressing menu-6-1-5 on the TV1 remote. Thanks for using Fix Ya. If I can be of further assistance please let me know.
Jan 28, 2009 | DISH Network DVR-625 DTV Receiver /...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
How do i choose tv1 or tv2 on my DVR?
Your recording will record onto your one DVR box, for playback on either tv. On many satelite boxes you have to search for the program you want by entering the name. Then select the program and select to record the future broadcast.
Dec 07, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 - Audio Problem
FIRST TRY CONNECTING THE RECEIVER TO THE TV VIA A DIFFERENT MEDIUM SUCH AS RCA INPUTS IF CURRENTLY CONNECTED WITH COAX.
If the problem is still evident you can send the TV1signal to TV2 or vice versa. This is accomplished by switching the output cables from tv 1 to tv 2 and changing the tv you want to use as your "monitor" to the proper channel. If viewing tv1 on tv2 change the TV channel from 60 air or 73 cable to 3. if using tv1 to view tv2 the process is the oppposite from 3 to 60air or 73cable.
To check which channel tv2 is modulated to do the following:
go to TV2 and with it on press menu, 6, 1, and then 5 on the Dish remote. That will dispay both tv output channels. You only need to be concerned with TV2.
This should isolate the problem by either it being present on both TV's using the TV1 output, which would mean the internals of the receiver are faulty, or if it is fine on the other TV it would indicate that the problem lies with the TV itself which is unlikely.This is assuming the FIRST method did noyt resolve the problem.
You may also want to try running the medium source from the back of the receiver directly to the TV.
This is all assuming you receive your locals through the satellite and not an off air antenna. Hope this helps you out.
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
103 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
