Question about GE Cooktops
We have an 8 yr old GE Monogram ZGU375LS 5 burner LP gas cooktop that an ignitor wire dropped inside, so, we need instructions on how to disassemble the base tray from the cooktop. The inner gas pipe connector that secures the base of the burner to the top was somewhat frozen from oxidation, and when I attempted to unscrew it, it appears that some internal gas tubing became misaligned, so, that burner has only a small blue flame, regardless of control knob position, and I smell a little propane when I tested the burner. How do I remove the galvanized steel base tray from the top assembly to retrieve the igniter wire and re-align - reconnect the gas connection to that burner? Thanks, steve
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
  • 221 Answers
SOURCE: We have a Thermador Mod SGCS365RW 5-burner that
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Posted on Feb 05, 2010
heatman101
  • 43501 Answers
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
heatman101
  • 43501 Answers
SOURCE: Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Posted on Sep 30, 2010
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
I have a GE Monogram Gas Stove - 5 burner. All
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Aug 09, 2008 | GE Cooktops
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Stove-top burners
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Cooktops Logo
159 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
