Question about Video Game Consoles & Games
Dropped my ps3, now it still turns on, but it says" cannot start, couldnot connect/find the right hard drive. What do I do?
    Scholar:
  • 81 Answers
It sounds like you dislodged the hard drive from it's connections. Your going to have to take apart the console to fit it back into place. Don't worry, that's not as hard as it sounds. Use the link below to see how to check your drive. The process is meant for swapping out the drive to replace it with one that has more space, but the process is the same. If you set the drive back into place and you still get the same message, you may have damaged the drive itself. In that case, kiss goodbye to whatever data you had on there, and go buy a new drive and install it using that same link. You'll have a PS3, but none of that old data.
http://www.instructables.com/id/Upgrade-Your-PS3s-Hard-Drive/
Posted on Oct 04, 2010
I dropped my ps3 and now its sayin it cant find its hard disk. how do i fix this?
If under warranty, ship to Sony. If not, check to make sure the hard drive in secure in it's hatch. There is a decent chance that,
  1. The hard drive connection is loose
  2. The hard drive connection is broken
  3. Internal Wiring is broken.
If it is 2 or 3, then you'll need to get repairs or buy a new console.
May 07, 2012 | Sony Playstation 3 (PS3) Console
PS3's connected by either AV or HDMI port, and the error appear: "cannot start correct hard disk not found"
Hi logan86,
Do you have an Hard Disk inside your PS3? if you do then try reformatting your hardrive again to a FAT32 format. To do so, when your ps3 console is turned off remove the hard-drive and connect it to a PC. Then use this software: http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm to format it to a FAT32 format and after that connect it back into the PS3.
Warning: This will result in the loss of all data on your hard-drive but it's the only chance of using that hard-drive again.
Hope this helped!
-Luchen
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 screen says " cannot start, the correct hard disk was not found." after turned on. will do nothing else. any ideas?
A long shot but it sounds like your hard drive has basically "switched off". If you have a USB sata hard drive dock I can help but its a bit of a complicated process. You need to remove the hard drive from the PS3 and plug it into the USB sata dock then connect it to your computer. Goto Control Panel -> Administrative Tools -> Computer Management -> Disk Managment. Look in the lower area of the screen that appears for your PS3 drive, probably E:, and look if it says "Not initialized". If it does, right click where it says that then click Initialize Disk. Put it back in your PS3 when it is done and hopefully it will turn back on. You will lose all saved data though as the hard drive will need to be formatted.
Hope this helps
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
I dropped my Ps3 accidently, and now it's behaving
if it does not read games anymore ( like if you insert a cd and it doesn't start working ) that means that the hard drive ( the part that reads the game discs ) is broken , why : because when you dropped your ps3 the head of the actuator arm scrached the platter ( the platter is sensitive , even a tiny scratch will stop the hard drive from working ) , so the solution is to change the hard drive , i hope i helped .
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
Ive dropped my ps3 and now it says cant find hard disk
either its jolted the connection to the hard drive or the hard drive has been damaged, but you can replace it, its just a pc hdd
Nov 15, 2009 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
I turn my ps3 on and the lighjt stays red when i hit the on button it turns green and starts to load but stops and all i see is wavy lines across screen what is the problem?
If the wavy line is like static I no exactly what you mean My old Laptop did that to me but that's because my niece dropped it so you might want to think back if you have ever dropped it if not then you might need to get a new hard drive for it because PS3's have a tendency to Screw up because mine wont play any games it just doesn't even try to read the disc but you might have left the system on too long and fried it as well. so i suggest you either have a professional look at it or replace the hard drive and i doubt you want to buy a new system so i hoped i helped you out ttyl BYE.
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes before getting to main menu!!
I had the same problem bud. I rushed and contacted sony but the next day my friend told me a great solution tht safed me 150 $. Well basicly your ps3 is lika a PC. All you nerd to do is to get to the hard drive menu. By holding the power button for 10 sec but do that for 3 times. That will take you to the blue menu. From there just reset your hard drive and wola brand new.
Ps Same thing happend after i downloaded the house app. booo to the house lol
Jan 20, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 problems again
Have you tried pulling out the hard drive and then turn it on to see what it does? If it says the same thing the hard drive may have died if not put the drive in making sure its firmly seated and power back up, make sure the power is off before you do anything. Was the system dropped at all?
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
