I am getting an error on a Canon clc 1120 E804 is this a fan motor error in the power supply? If it is Is there a part number for it. Thank You
  • 10,515 Answers
E804- The stoppage of the cooling fan for the power supply unit is
detected. You have to change the fan or clean it other wise this error keeps on coming back.
You could have a look at the service manual from :-
http://www.scribd.com/doc/26610238/Canon-CLC-1120-1130-1150-Service-Manual
It would have all the details you need to fix this problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
Ir5000 error codes E804 -0000
dc power supply fan. open the left covers and you will see the dc power supply in that board you got fan. and switch on the m/c if it's rotating.
Jan 11, 2013 | Canon CLC 1120 Color Copier
Canon ir5055 error e804-000
A E804-000 is a problem with a fan not working correctly. I believe the fan is on the main power supply..... You can try to clean the fan, but the only draw back is that there is not a part number for the fan only... You have to replace the whole power supply..... Good Luck
Sep 04, 2012 | Office Equipment & Supplies
IR 6570 Error occurs E804-002
This is an error for the DC power supply fan - there is an IH power supply cooling fan error. The book I have doesn't give the 002 part of the error but check that
Jun 21, 2011 | Canon imageRUNNER 5570 Copier
6570 - e804-0001
E824 There is a primary charging cooling fan error.
0001 The primary charging cooling fan stop signal has
been detected for 5 sec or more even when the
primary charging cooling fan is on.
Service manual says:
- Check the connection of the connector.
- Replace the fan.
Why did you changed power supply? Did you try with new dc controller?
Jun 29, 2010 | Canon imageRUNNER 5570 Copier
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
E 804-005
E804
detected.
Jul 07, 2009 | Canon CLC 1120 Color Copier
Canon CLC 1130 Code E 072 0202
The transfer drum cleaner brush
motor (M8) is faulty.
The polishing roller motor (M9) is
faulty.
The motor drive system is
subjected to an overload.
The attraction/transfer locking cam
motor (PM7) is faulty.
HP sensor (PS8) is faulty.
The registration path driver PCB is
faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
Mar 12, 2009 | Canon CLC 1120 Color Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
77 people viewed this question
k24674
jasbo
jasbo
