Question about Health & Beauty
How to open remington ms3 1700 electric shaver to change battery and battery type??
  • 1 more comment
  • sklardentist Oct 04, 2010
    thanx, i'll let you know the results, sklardentist
  • Wayne Ashby Aug 06, 2013
    For the MS3 1700, I did it -- it was easy! First remove the shaver screen and cutters. To replace the batteries, remove the screw on the back near where the charger plugs in and also remove only the two screws found under the cutter assembly area, nearest the backside, that are screwed into the black plastic (not the ones screwed into the metal plate). Pry the back cover off starting a the end where the charger cord plugs in. It may be a little sticky because of the rubber seal, but it will pry off. The batteries are then accessable.
    ...for the MS3 1700, I ordered the two replacement NiMh AA flat top batteries, 2000 mAh w/solder tabs replacement batteries from Amazon.com for a total of $5.90. You will need a soldering iron to unsolder the wires from the battery tabs...
  • Health & Beauty Master
  • 1,600 Answers
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Posted on Oct 04, 2010
  • 2 more comments
    screw on bottom suggests opening should be possible but thanks, I will try gingerly,sklardentisr
  • shaveroutlet.com
    shaveroutlet.com Oct 04, 2010
    Yes, there is a screw on the back but you will still need to remove the side grips and the oscillator assembly at the top.
    If you do get it open without damaging it too much, you willfin the correct battery type at shaveroutlet.com. See link below. You will need two batteries
    http://shaveroutlet.com/shaver-replaceme...
    -good luck
    I did it -- it was easy! First remove the shaver screen and cutters. To replace the batteries, remove the screw on the back near where the charger plugs in and also remvove only the two screws found under the cutter assembly area, nearest the backside, that are screwed into the black plastic (not the ones screwed into the metal plate). Pry the back cover off starting a the end where the charger cord plugs in. It may be a little sticky because of the rubber seal, but it will pry off. The batteries are then accessable.
I have no manual. My ms5500 isn"t charging properly and while it is on charge, it gets very hot.
Battery is wearing out. You can change them. See link below for correct battery type from shaveroutlet.com
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
An easier thing to do would be to purchase a factory refurbished MS-5200 from shaveroutlet.com. See link below. It is the same shaver as the MS-5500 but does not come with the clean/charge base.
http://shaveroutlet.com/shavers/remington-ms-5200-titanium-cord-cordless-shaver-factory-reconditioned.html
Nov 28, 2010 | Remington MS5500 Electric Shaver
I need to change the batteries and need the type
You will find batteries for your model at shaver outlet.com. See link below. You will need to order two batteries
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Apr 19, 2010 | Remington Titanium Microflex R-950...
Battery needs charging every 2 days
You will fin the correct battery type at shaveroutlet.com. See link below. You will need to order two batteries
Apr 06, 2010 | Remington Titanium Microflex R-950...
Health & Beauty Logo
1,015 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
