Question about Microsoft Windows XP Professional
Can't get on a game site I use all the time. microsoft VBScript runtimeerror800a000e
    President:
  • 2,291 Answers
Restart ur pc and run reginout cleaner and then change ur proxy settings and then check it will work
Posted on Oct 04, 2010
When advised [repeatedly] by Incredimail to update my version Of Incredimail 2, I finaly get a error 2738 could not access VBScript runtime for custom action. Any one help?
Microsoft has created a Fix-It for this!
What this Fix it does is to remove incorrect or corrupt registry entries that interfere with VB support in windows and then re-registers the DLL ensuring that the correct registry setting are there. After running the Fix it solution you may be able to immediately try the operation that previously gave you the error, but to be sure, a reboot is suggested. This will address similar issues with other programs as well and not just the applications that are specifically mentioned in this thread.
The link to the Fix it is: http://go.microsoft.com/?linkid=9804433
If you want to do it without any software then here is the Link to view the solution ERROR 2738
Aug 04, 2012 | Microsoft Computers & Internet
I am using Vista business and have error msg 2738 and now cant uninstall my internet modem. please help
re-registering VBScript.dll should fix the problem.
Here are the steps: 1. Run a command prompt in administrator mode (Start/All Programs/Accessories/ right click on Command Prompt, select Run As Administrator) 2. type: cd %systemroot%\system32 3. type: regsvr32 vbscript.dll
Note, regsvr32, not regsrv32. You should see a dialog stating the registration succeeded.
Mar 01, 2011 | Microsoft Computers & Internet
Microsoft vbscript runtime error 800a0108 object required pool line76
update ur os, clean registry using reg in out and install .net frame update
Sep 14, 2010 | Microsoft Windows XP Home Edition
Microsoft VBscript runtime error 800a000e out of string space /_icontent asp line 141
Hi, Was it a web site that you browse returned the error or your site while you were testing? If its your site its better if you could post the line of code as well which is the 141th.
You have to follow one of these steps to solve the thing.
  • Using the Erase statement to reallocate Dynamic Array Storage
  • Use the Re Dim Statement to do so
  • Close any unnecessary files, documents or source files
Try to check whether it would work after following the steps. If not contact me again. If the solution worked for you, please Rate the answer! Thanks for contacting Fixya!
Jun 29, 2010 | Microsoft Windows XP Professional
Cannot download itunes since a recent firmware upgrade for ipod touch, went to apple forum site and told to delete apple,quicktime, apple mobile device support and now i can`t get itunes to download onto...
Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Resolution Download and install the latest version of iTunes.
Install the latest VBScript engine from Microsoft for your Windows OS platform Windows 2000 Download and install VBScript version 5.6 for Windows 2000 from Microsoft, and then try installing iTunes or QuickTime again. Windows XP Download and install VBScript version 5.7 for Windows XP from Microsoft, and then try installing iTunes or QuickTime again. Windows Vista No download necessary. The latest VBScripting engine (version 5.7) is already included with Vista. Follow the steps below to register the VBSScript again if you still have this issue in Vista.
Register the VBScript engine again If the latest VBScript engine is already installed, register it again. Note that you must be logged in as administrator or logged in as a user with administrator privileges for the computer to execute these steps.
For Windows 2000 or Windows XP: 1. On the Start menu, click Run.
2. In the "Open" field dialog box, enter the following command and click OK:
3. A message should appear stating that the "DllRegisterServer in vbscript.dll succeeded."
4. Click OK and try installing iTunes or QuickTime again.
Oct 19, 2009 | Apple iTunes
Internet option flashes and dont work
hi,
unregister and reregister vbscript.dll , jscript.dll . here is the command: regsvr32 vbscript.dll and regsvr32 /u vbscript.dll . ( make sure that browser is close d when you do this.)
if it still doesn't work it could be a corrupted browser. uninstall and reinstall.
for uninstallation : control panel add or remove programs.
reinstall by : http://www.microsoft.com/downloadS/details.aspx?familyid=9AE91EBE-3385-447C-8A30-081805B2F90B&displaylang=en
Jun 06, 2009 | Microsoft Internet Explorer 7
VBScript compilation error ''800a0408''
The Symptoms you get The script does not execute as you had hoped. Instead you get a WSH message box.
The Cause of error 800A0408 Your VBScript contains an illegal character, often at the beginning of a line. It can happen if you copy the script from word, then paste into notepad. For example, to 'Rem out a line we need the apostrophe, which is ASCII character 39; however if you paste from word you may get ASCII 96 (Grave accent).
Note the clue Source: Microsoft VBScript compilation error, this means a syntax error in your script.
The Solutions Check the punctuation marks in your VBScript, particularly look out for apostrophes and commas that do not display correctly. The reference to Line: 1 Char 1, means that the very first symbol that is probably wrong.
Mar 13, 2009 | Microsoft Computers & Internet
Logitech pro 9000 software
If you are using windows xp then you should download this fix from the microsoft website. http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displaylang=en
If you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Aug 15, 2008 | Logitech Webcam
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Microsoft Windows XP Professional Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
