Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Brush will not turn and machine has stop self-propelling forward.
  • 377 Answers
Two things to check out. 1- Any broken belts that need to be replaced? 2- Brush is frozen and needs to be removed, cleaned and lubricated and reassembled.
My guess is there is a problem with the belts.
Posted on Oct 04, 2010
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Doesn't propel forward anymore
if not the height setting, then
there is an obstruction or the brush is getting worn out.
Aug 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
I have a self propelled Royal Dirt Devil vacuum model number 087900 and it goes backward fine but forward has to be pushed so hard it's impossible. Is this a switch? Do you know about how much the part...
You might try a new belt and/or brush roll. The brush roll is what helps pull a vacuum forward, the power drive helps, but if the brush isn't turning like it should, then it will hinder forward motion. The belt may look ok, but they stretch to the point that under load they won't drive the brush roll.
Feb 28, 2008 | Vacuums
Hoover windtunnel Self-propelled - brush roll stops
There is a idler wheel that will drive the V belt, sometimes they jam and you just have to reach in, push and make sure if comes in contact with the belt. Alot of times tho it is the other flat belt, 38528035 that will stretch and can cause you to have problems with the brush roll not turning.
Feb 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
98 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
