Question about Whirlpool LER4634J Electric Dryer
How do I replace the thermostat in whirlpool model ler4634jq1. and how many thermostats are in the unit? I was told there are two.
  • Whirlpool Master
  • 7,482 Answers
There is normally two thermostats...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 04, 2010
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
Wher do i find a thermal switch for whirlpool water heater
1) Call whirlpool and give product type, model number, and serial number that shows on label on side of unit.
1-877-817-6750
2) For gas: Likely they will send whole assembly
http://waterheatertimer.org/How-to-replace-thermocouple.html
3) For electric thermal switch, just replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Repost question and include information on label
5) Call service technician
Jan 01, 2013 | Whirlpool Water Heaters
Where can I locate a thermostat for my whirlpool oven model #RS6100XVN
go to www.repairclinic.com and buy give your model, serial number, mark, and ready.
God bless you
Jul 27, 2012 | Kitchen Ranges
Frezzer frozon
as you haven't mentioned the model number i have 2 options, Basically what is happening is that the thermostat is not detecting that the freezer has reached it's lowest temperature, So you need to replace the thermostat.
On some models the thermostat is a mechanical part which is quite cheap and easy to replace, on other models it uses an electronic control unit with sensor probes, these can be a bit more difficult to fix and the parts tend to be more expensive.
Mar 07, 2012 | Whirlpool Refrigerators
WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Jul 30, 2010 | Whirlpool Refrigerators
My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
I have a roper electric dryer that runs, but will not heat and the timeR will not shut off on any cycle. My model number is a LER4634JQ1 Can you help?
Your timer is fused. have it replaced immediately. it has failed.
You must also replace the hi limit thermostat and thermal fuse as well.
Aug 13, 2009 | Dryers
My whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
Jul 28, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
615 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
