Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a lift master garage door opener. when opening and/or closing it will stop and the light goes off. if you tap on the black plastic panel, the light will come on. what could be the problem
    President:
  • 3,197 Answers
You need to pull the logic board and look for loose connections on the printed circuit especially around the small transformer.
Posted on Oct 04, 2010
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
Feb 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Vacation mode keeps coming on our craftsman lift master garage
You possibly have a bad wall control. You say it comes on as soon as the light goes out. What light are you referring to?
Jul 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old 139.53985dm garage door opener shuts off going down
Unplug unit at power source and check and tighten all connections in the control box. And try this link.
http://www.garagedooropeners.us/technical_information.html
Mike
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
52 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
