Question about Whirlpool Calypso GVW9959K Top Load Washer
Code on washer is CE--What does this mean and how do I reset the unit??
    Sergeant:
    Champion:
  • 351 Answers
Communication error if there is any breakdown in communication between the machine controller and the motor.controller, ce flashes and the unit beeps once
Posted on Oct 04, 2010
What is the problem with my washer whan it has an erorr code CE ?
You have to tell us make and model to get a precise answer.
On many washing machines CE means communications error which is either a failure of the control board or some item controlled by the control board. It may be time to call the repair man.
Apr 18, 2015 | Washing Machines
Code ce dont turn on
The CE error code is indicative of an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit, and refer to service
Thank You
Sep 12, 2010 | LG WM-2277HW Front Load Washer
Will not pump out water and getting CE, OB, and LD codes.
Hello, check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short. The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them.
Thanks
May 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Press STOP/CANCEL to clear the display.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How can i fix the CE code on my washer? the CE code appears when i turn on the washer then it turns off.
The "ce" code indicates that a communication error occurred between the central control unit and the motor control unit. This can be caused by poor or loose electrical connections, especially at the motor connector. Unplug the machine before attempting any repair. The electrical connections can be unplugged and reseated to clean off corrosion. Also look for any damaged or burnt insulation on the wiring. If these steps fail to resolve the problem, you may want to consult an appliance repair technician for assistance. Sorry for your trouble and best wishes.
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Mar 08, 2009 | Whirlpool Washing Machines
Kenmore Elite Top Loader "CE" error code.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
194 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
