Question about HP Pavilion a6750f PC PC Desktop
My HP Pavilian a6750y tower when turned on fan runs , but no light on powere button and moniter is blank
  • HP Master
  • 5,660 Answers
Indicates you have a bad Power Supply, to me.
Weak voltage power rail.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
(The Pavilion a6750f uses an ATX power supply, that has a maximum rated wattage of 300 Watts.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01619697&lc=en&dlc=en&cc=ca&lang=en&product=3872428#N934
The AMD Phenom X4 9650 processor can use up to 95 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Agena.22_.28B2_.26_B3.2C_65_nm.2C_quad-core.29
(In the chart under the heading TDP)
Enough power to spin fan's, but not enough to turn the Processor on.
Not enough to also light that Power On LED light.
No Processor operating = No Video Signal from the computer.
Hence the monitor is blank.
(No Signal)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&tmp_track_link=ot_recdoc/c01619697/en_ca/c01356113/loc:3&lc=en&dlc=en&cc=ca&lang=en&product=3872428
NOTE*
Computer unplugged from power.
Anti-Static Precautions observed.
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
(You may not even see it, or feel it)
Computer unplugged from power, computer case open, working on a table;
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be be SURE to Touch the metal frame again.
Posted on Oct 04, 2010
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
I have G5 PPC mac tower - power light is on, but the unit will not turn on. No fans are running. Just a bright white light on the power button.
First if side door or plastic shield is off, fans won't come on and unit won't start. Fans only run when unit is running hard and that's not always. Back to your original issue - not running, couple of things to try - first being side door and latch on back, make sure both are closed. Try restarting by holding start button on front of tower. If that don't cure it, disconnect power lead in rear for about 30 secs then try to restart.
Feb 26, 2011 | Apple Power Mac G5 Desktop
My computer tower will not turn on. I tried the steps listed on the HP web site, disconnected the power cord, and all cords connected to tower and held power button for 5 seconds, then plugged power cord...
black screen , totally is here,
one page covers this.
http://pcdied.com/black-screen.html
test one do all Desktop fans run
if not the PSU is bad. 99% we can 1% if PSU is ok.
May 06, 2017 | HP Pavilion a1630n PC Desktop
I have an hp pavilian atx-250-12z and the tower itself will turn on and the mouse to will turn on but the monitor gets no signal and the keyboard will not turn as well..I have unplugged the cpu while...
Whom ever told you too: "Unplug the cpu while holding down the power button".
Is telling you something that can "seriously damage" your cpu and computer.
Or did you mean "PSU" if so there is a particular format to do a Power supply check.
For the proper way use this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&product=405227&dlc=en&lang=en#N207
Also many other things can cause the problems your having. Could be your motherboard too.
If this does not work, post again be sure to include HP Pavillion Model number and Operating System (i.e. XP, 7 or Vista) that way we can help pin point your system needs. Also have you done any internal repairs lately? Recheck all your connections too.
If you find this helpful please vote.
Oct 07, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
HP Pavalian laptop screen gone black and blank.
It seems like the lcd back light may have failed can you see a faint image on the screen when you look really close, try it with a torch. If you dont see even the faintest image the inverter has failed and needs to be replaced. If you look on youtube again and search for videos of replacing both the back light and the inverter it will give you some info on how to change them. Do a google search for hp spares and you will probably find what you are looking, i think the inverter is about £30 and the back light is bit cheaper. hope this helps.
Feb 11, 2010 | Computers & Internet
Solution for ''hp computer a6020a wont turn on after two months packed away'' it worked fine then went away for two months and now will not turn on has power but no blue light and nothing happens all fans...
HP has been really great with my pavillion desktop and its out of warranty and they still help me with the issues and help me solve them it may take a while to get it taken care of you may have to emial back in forth to get your promblem taken care of. Here is the email support that you can try just provide the modle number and the serial number that should be located on one side of the computer or on the bottom of the tower, and Good Luck!
PAVILION_SUPPORT_EN@MAIL.SUPPORT.HP.COM
Jan 06, 2010 | HP Pavilion a6000n (882780985018) PC...
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Won't load windows...
you video card is not working.... if you have onboard video use that until you have installed the driver for your add on video card
Apr 16, 2009 | Dell Dimension 3000 PC Desktop
HP Pavilion a6750f PC  PC Desktop Logo
453 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
