Question about Samsung DCS 12 Corded Phone
Need help forwarding phones
We have 5 lines, line 701 is the main line that has the call forwarding feature on it, from the phone company.
When we dial out, there is no logic that I can see as to what line is selected. Sometimes 702 is selected, sometimes 703, etc.
I need to have one extension that always selects 701, so that when we go to forward the phones from this extension, we will always have the 701 line selected.
    Scholar:
  • 108 Answers
The programming on the Samsung should be set so that your highest line number is selected when you call out, this leaves your first line available for incoming calls. If you want to access line 701 from any phone you should be able to just dial 701 instead of dialing " 9 ". Let me know how is goes. ...Mike
Posted on Jul 31, 2008
Cancel call forward
to cancel intercom call forward press the call forward key again or feature #4
to cancel a line call forward choose the line and dial *73 or whatever the phone company's cancel call forward code is (may be in phone book)
Feb 10, 2015 | NorStar M7324 Telephone
How do I forward calls from Panasonic KXTG4500 to my cell?
Call forwarding needs to be activated by your phone company and then set up through your account settings. The phone itself cannot forward calls. You would need a two-line phone with call forwarding features and two separate phone lines to accomplish call forwarding locally.
Feb 02, 2015 | Panasonic KXTG4500B 5.8 GHz 4-Line Corded...
HOW TO CALL FORWARD TO CELL PHONE NUMBER
There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
Sep 03, 2014 | Mitel 5330 IP Phone
How to divert an incoming call?
There are several methods. Phone company provided call forwarding instantly sends calls to a phone number you set on your main phone line, that you turn on with *72 + the destination # and turn off with *73. Or "Call Forwarding No Answer" that transfers the call after several rings to a pre-determined number, all setup by the phone company on your main line. Or, on the Panasonic systems (there are many), you do the same using several code choices, a bit more complicated. Your installer must set the system to allow the system to send calls to an outside line, and you must have more than one line because the destination number is dialed on a different line than the line that's receiving the call. Your Panasonic "Operating Manual" lists these codes and methods with instructions, you'll find them listed in the table of contents under "Call Forwarding" with step by step pictured instructions.
Apr 09, 2014 | Panasonic KX-T7730 Corded Phone
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
Avaya Partner 18D Corded Phone...
Yes. Call forwarding is a feature provided by your telephone company, not a feature of any phone, and the procedure is dependent on the company. For some telephone companies, for example, you forward a call by dialing *72, waiting for a second dial tone, then dial the number to which you want calls forwarded. Please contact your telephone company for their exact procedure.
May 28, 2012 | Avaya Corded Phone avaparp18d
How to unforward a phone from the main line
press the call forward key on the set that is forwarded. if no forward key press feature # 4.
Feb 15, 2012 | NorStar M7310 Corded Phone
How do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Mar 05, 2010 | Nortel T7316E 2-Line Corded Phone
Nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
Nov 10, 2009 | Nortel Norstar 16-Line PBX Speakerphone
No issue, just a question. Looking at RCA 25425RE1 4 line business phone system. If all four lines are busy , will the caller of the 5th call get a busy signal or does the phone have "busy no answer...
ANY phone system will have this problem.
If 5 people call in, the first 4 will be answered, but the 5th will get busy, as there are no lines available into your phones voicemail system.
IF, you have voicemail through the phone company, you can get their voicemail feature for extra.
THEN, if 5 people call in, the first 4 go to the phones, and the fifth gets the voicemail greeting.
It would be dependant on the line provider how many calls their voicemail would handle at one time. SO if 500 people call in, 4 get through, and MAYBE 5 go to voicemail, the rest get busy.....
Jan 13, 2009 | Lands Phones
Samsung DCS 12 Corded Phone Logo
136 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
