Question about Maytag Neptune MAH5500B Front Load Washer
After the final spinn cycle ther is still water in the washer
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 04, 2010
Agitates and drains but smokes when it is time for finall spinn....wont spinn
Thanks for choosing FixYa and welcome. You need to make sure you don't have a frozen pulley. The belt may be causing the smoke you are seeing. It may be coming from the motor drive. None the less, it needs checked out.
Jan 09, 2011 | Crosley CAWC529JQ Top Load Washer
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
Top load direct drive will not spinn, but pump water out.
COUPLING BETWEEN MOTOR AND TRANSMISSION IS SHEARED AND NEEDS REPLACED.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes still very wet after spin
Common problem if drain tube goes to laundry tub. Tub drain is slow, so water is siphoned back into washer at end of cycle.
Other solutions: Partial blockage of drain tube before or at water pump. Take off front washer panel, exposing pump and disconnect hoses. Remove obstructions and re-assemble.
Jun 12, 2009 | Maytag PAV2300 Top Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
