Question about Whirlpool WTW6400SW Top Load Washer
What does the code PO mean? - Whirlpool WTW6400SW Top Load Washer
  • 2,382 Answers
Hi, PO means Pump Out (lid opened).
Po flashes when drain pump begins pumping out water from tub upon activation by the door lid having been left open for more than 10 minutes.Close door lid to stop drain pump.
Posted on Oct 04, 2010
Sankey inverter 12000 split unit give error code PO what does this mean
PO code means power went off unplug unit to try and reset , also check for power to unit .
Oct 03, 2014 | Heating & Cooling
Po 171, po 305, po 441
Hi, I know from my past experiances the spark plug wires at the boot ends than slide onto the sparkplugs usually over time short out due to the metal tubes that protect the sparkplugs from heat kind of ark across from the metal tube through the plug boot causing an error code. Sometimes in the dark you can actually see them arking at the tube on the engine, and also hear a crackling noise. As to the code for the O2 sensor that's a normal wear and tear item that may need replaced. As all vehicle age over time electrical connections, and things have issues develop and cause havick with sensors and computers in these vehicles too.
As with the 441 code and then the other code for the O2 sensor showing up may mean both O2 sensors are going bad if your system has 2 sensors in the exhaust, usually one before the cat converter and one behind it. A lot of this also is due to what gasoline you use in the vehicle over time. Lower octane gas may be what is causing things to act up.
Jan 03, 2014 | Dodge Ram 1500 Cars & Trucks
What could PO 302, PO 300, PO 105, PO106, PO 110,PO 115& PO 120 CODES Mean on a Toyota Camry 2000 model sedan car?
what engine, what size. that is first question.
misfire, map ,maf, iat, ect,tps and cat fail and low coolant temps.
very odd mix there. did you pull connections, key on???????
it means they all fail a test.
DIY? or just curious?
login to alldata.com
the question is , which is the most important.
all are cept 420, (last that, and bet goes way. later.)
reset the ECU, and see which come back.?
check all fuses.
then post codes that repeat, after fuse checks.
does the engine get fully hot running, 180F minimum?
Nov 27, 2013 | 2000 Toyota Camry
Codes nissan
Nissan Altima 3.5 2002 code p1102 and p0057
whats theses mean.
May 04, 2013 | Pico Technology PP337 ACE Misfire...
Po316, po 300, po301, po305 2004 ford freestar
These codes are making me lean towards the ignition coil pack.My stepson's 2001 Sable 3.0 v6 had one cylinder misfiring(5-code P0305),which shares a coil with cylinder 1(code P0301).I diagnosed it by trading wire 1 and 5 at the coil,and the code changed to P0301.You have codes for the two cylinders on the same coil,so this is most likely it.(these codes would also trigger P0300(Multiple Misfires Detected) and P0316(Misfire Detected First 1000 Revs)).
Oct 14, 2012 | 2004 Ford Freestar
2006 6.8 l V 10 ford Check engine lite on code po 182 and po 460
this obd2 trouble code table can help you understand the meaning of code.
and for your code, I think you can try to change the whole sending unit with the fuel pump in the tank. And see if the code come back.
Sep 14, 2011 | Ford E-350 Super Duty Cars & Trucks
Truck has 10 different PO codes
171 and 174 mean not enough fuel po 300 multiple missfire could be not enough fuel 430 can be caused by bad ignition in the cat from not enough fuel // first thing borrow a freinds mass airflow sensor
Jul 06, 2010 | 2005 Ford F 350 Super Duty
My check engine light came on 2004 ford taurus had a friend the plugged one of those code readers in got two codes po 174 and po 171 what do they mean
P174 means Oxygen sensor was slow in switching Single, Right or Rear HO2S - Fuel control
P171 means Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S - Fuel control
Visit http://www.troublecodes.net/Ford/
for a comprehensive code listing for your car.
Please rate this solution.
Thanks for using Fixya!
Jan 08, 2010 | 2004 Ford Taurus
I have a error code reading of PO 743, Torque converter clutch, what does that mean?
It sounds like the convertor in the exhaust system is partly blocked. You will need to have this checked at a shop. Frankster016
Oct 26, 2008 | 2000 Ford Expedition
Check engine light on
P0700 - Transmission Control System Malfunction, this is a transmission or PCM issue and needs further diagnosis with other test gear.
The P1684 code simply means that the battery has been disconneted within the last 50 engine starts.
Sep 09, 2008 | 2001 Dodge Caravan
Whirlpool WTW6400SW Top Load Washer Logo
227 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
