Question about Dual Milwaukee 6950-20 12" Bevel Compound Miter Saw
I own a Milwaukee 12 compound slidesaw 6950-20. After using the saw -when I release the on-off handle.the saw makes a loud chatter sound-I think it is the brake and have read their is a brake adjustment.Have you heard of this problem and how do I fix this? Thanks,Peter Haskell
    President:
  • 1,388 Answers
The break works by shorting the windings. An electric current is produced within the armature forcing it to stop. There is no adjustment. As the rotation slows the current is reduced till stops then no current. Unusal noises can be produced when windings are loose within housing or armature bearing are worn. Also could be that the blade is slipping or drive gears need lube. I would remove blade and look for indication of slipping. If no slipping run saw without blade and see if noise is reduced. Also I would use the lightest blade available. Heavy blade places greater load on gears to start and stop. Good Luck
Posted on Oct 04, 2010
How big of a Miter saw should i get?
a good 10 incher will handle most DIY jobs .compound slide saw
Mar 02, 2016 | Dewalt DW715 Heavy Duty 12" Single -...
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
How to put a new cord to a sawzall?
you can buy a replacement cord from just about any shop or go to milwaukeetool.com for an exact replacement. UNPLUG tool and remove the handle half, make note of the wiring, if the ends of the cord are soldered you will need a paper clip to release them from the switch, just slide the clip next to the wire and PULL GENTLY to remove, Solder the new ends using the old cord as a template and when inserting pull gently to make sure the wire end seated into the switch. Reinstall the handle half and test.
Jan 03, 2012 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
remove the handle half and make note of the wiring. If the cord has been soldered you will need a paperclip and straighten one end of it and slide it next to the wire to release it and pull the wire from the switch. After inserting the new wires of the cord GENTLY tug to make sure it locked into place. Let me know if you need more assistance.
HOw to lift the saw in the up position
i have a bosch   it has a little knob on the side that i pull and give a half twist and release   then the arm will raise and fall until time to store it again
Nov 07, 2009 | Makita Tools 12" Compound Miter Saw -...
Craftsman compound miter
if its like my dewalt, u have to unscrew it before u canunlock the handle. try unsrewing it.
Sep 05, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Dual Milwaukee 6950-20 12"  Bevel Compound Miter Saw Logo
73 people viewed this question
Top Dual Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Dual Saw Expert? Answer questions, earn points and help others
