Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I can turn my mitsubishi big screen tv on. I was told it was in sleep mode. The timer light on the front of the tv is constantly blinking and I don't have a remote. How can I fix it?
Unplug it for at least 30 minutes then try again
Posted on Oct 04, 2010
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Nov 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Need to try self diagnosis, it's here in threads. If not you need live chat!
Oct 01, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
