Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bex Bissell Pro Heat 7920-E
I need to replace the water pump. Can you tell me how
  • tankrat May 28, 2008
    Thanks for the help
  • hammons7 Aug 02, 2008
    How do I know that the pump needs replacing on this. My water hardly comes out, but I was thinking it was the switch not making connection. My flow wheel won't turn, Once it a great while it will. I have replaced O rings, the screws that attach the upper handle to the attachment case, they sent the wrong length. I replace the shampoo and lid deal. cleaned everything good.
No water nosuction
Posted on Apr 28, 2012
    President:
  • 1,673 Answers
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
Posted on May 28, 2008
WATER PUMP
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eyhj
May 08, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get the water to spray out when I turn it on?
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Dec 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bex bissell delux carpet washer is not sucking water up, can you help thanx.
I had the same problem, take the water tank out, look on the bottom, is there a red seal on the tank? If not, its either lost (can get new one here http://www.4bissell.co.uk/cgi-bin/product.pl?PID=947370&query=7920%2de) or more likely its stuck in the bottom, if it is get a screwdriver and prise it out of the base and put it on the tank. All should be well. Regards Paul
Aug 01, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Water/solution flow problem
check your belts. if your brush is not spinning when you have it on, it is a belt. goto bissell.com and there you will find on line videos to help you with this troubleshooting process, it will also tell you how to change it.
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Water and soap coming out wheel area
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
PRO HEAT 2X BEX BISSELL THE SOAP GETS RELEASED BUT NO WATER TRIED CLEANING
Either the heater unit is blocked, clean it out, or I had the same problem, take the water tank out, look on the bottom, is there a red seal on the tank? If not, its either lost (can get new one here http://www.4bissell.co.uk/cgi-bin/product.pl?PID=947370&query=7920%2de) or more likely its stuck in the bottom, if it is get a screwdriver and prise it out of the base and put it on the tank. All should be well. Regards Paul
Jun 30, 2008 | Bissell Vacuums
Bissell proheat 7920 replacement pump
Part number is 2107181, it will cost around $30. Most local shops shoul have this part or can order it for you. You could try bissell.com.
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
539 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
