Question about Dryers
My Maytag Dryer Drum does not turn
Please help
  • lg2sra May 27, 2008
    Not really helpful:The belt broke and I donot see any way to replace it.How to I take the drum out?OR>where iis the belt located that I need to replace;Electric maytagModel #PYE2300AYW.Thank You Donna orlg2sra@yahoo.com
  • 525 Answers
Inspect your belt(s), rollers, pulleys for seizing or breakage.
Posted on May 27, 2008
  • David Emmel
    David Emmel May 30, 2008
    I apologize for the delay in assisting you with the dryer issue.
    Thank you for providing your model #. This always helps save time as different models have different designs.
    Normally, when you purchase a drum belt, it will come in a plastic package with replacement instructions printed on the back. If you misplaced the instructions, The information listed below should be helpful, but may not be entirely accurate, due to factory design changes.
    1. Disconnect dryer from its power source.
    2. Remove the front panel by releasing the top panel from the front panel by placing a flat blade screwdriver between the top panel and front panel, at the corner wher both panels meet and gently pry upward to release the spring clips.
    3. Remove 5/16" screw at each corner where the front and side panel meet.
    4. Pull the top of the front panel slightly outward and lift upward, this should release the front panel from the base an retainer clips.
    5. Remove 4-5/16" screws from front bulkhead aand pull forward to remove.
    6. Slide new belt onto drum and replace onto motor pulley and idler pulley.
    7. Manually rotate the drum o align the belt on the drum.
    8. Reassemble and test run before putting clothes back in.
    Hopefull this will be of some value to you.
    Thank you for contacting us at FIXYA.com.
    Dave E. (Illeagle)
5 Suggested Answers
  • 833 Answers
SOURCE: Stains on Maytag dryer drum
This may be caused by some kind of wash product or softener product. You may be using too much. You can use a blue glass cleaner or small amounts of mild abrasive cleaner and water to try to remove it. Drums are made of porcelain or stainless steel and should 'never' wear out.
Posted on Dec 21, 2007
  • 113 Answers
SOURCE: Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Posted on Dec 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag dryer has knocking for every turn of the drum
Replace loose blower:fa3c9cb.jpg
Start here:
Posted on Dec 22, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Electric Maytag Dryer Performa: Front loading
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
My maytag dryer mde308dayw will not turn maybe belts broken help me out please
Use a putty knife to release the top then get the front panel off then remove the shroud and the drum. My home video of a dryer like yours:
Oct 07, 2012 | Maytag Dryers
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
New belt but drum still won't turn
make sure that he put the tensioner on the right way with the spring it will make the belt really tight !This is sometimes hard to do because the spring will bite you if your not careful !!
Feb 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Dec 16, 2008 | Maytag Dryers
The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Nov 22, 2008 | Maytag MED5770TQ Electric Commercial Dryer
Noisy maytag dryer
the blower wheel sounds like it is bad it should be tight on the shaft and not turn unless the tub turns
Nov 15, 2008 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
308 people viewed this question
Top Dryers Experts
