Question about Maytag Dryers
Our Maytag heavy-duty SD-6 dryer makes a shrill squeaking noise when running. Moving the drum from side to side will make it less or stope. Purchased in Aug 2006.
  • 4 Answers
THE BELT PULLY IS WORN AND NEEDS TO BE REPLACED
Posted on Oct 04, 2010
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire heavy duty electric dryer started with sqeaking noises now is knocking belt appears in place drum turns mannually feel somthing loose between drum and rear cover
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 14, 2011 | Frigidaire GLGR642A Gas Dryer
Dryer making a loud squeaking noise
Hi, You probably will need the following parts to fix the squeal;
6-3705180 Idler arm $6.78
6-3700340 bearing $16.04
[2] 6-3129480 Drum roller shaft $5.53
[2] 12001541 rollers $22.04
33002535 belt $23.80
MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT
Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
Jan 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Our heavy duty Inglis dryer (maybe 4 or 5 years old) is making a loud noise. The drum still turns. The heat still comes on and the clothes will dry. But the noise......Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Dryers
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Dryers Logo
224 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
