I have a Bryant furnace that is not heating. it comes on and the blower blows air, however it's cold. i looked in the window where the fire should be and there's nothing. there's no LED codes blinking on the control card. This is the first time i've tried to run it this season. the LP tank says that it's 30% full. Do you think the gauge could be bad and i'm actually out of LP? thanks for your help.
    Problem Solver:
  • 19 Answers
I would need to know the model of the unit. it could be a number of things depending on the unit - is it hi eff?
Posted on Aug 02, 2017
hotuna
  • 288 Answers
SOURCE: MHU 75 Model Mr. Heater
The roll out switch is a small disc shaped part about the size of a nickle. There may be more than one. anyway there is a button shaped like a small peg in the center if it, push it in and it should stay in. You may need to re examine the limit switch, because this is what it sounds like. they are rated for a set temperature, so your application may need a higher temp. A simple way to check parts like these is to by-pass them by taking the wires off the part and connecting them together. If this solves the problem, that it. My only concern is that this is a new installation, and maybe its not venting adequately or its burning up all the usable air in the room. That's why most of these parts are on the equipment.
Posted on Dec 24, 2007
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Posted on Mar 22, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Bryant Plus 90 Furnace - Blower works fine and
PRSSURE, DRAFT SAFGUARD, AUX-LIMIT SWITCH(WHEN USED)OR BLOCKED VENT
SWITCH(WHEN USED) DID NOT CLOSE OR REOPENED (DOWNFLOWONLY)
If open longer than five minutes, inducer shuts off for 15 minutes
before retry.
Check for:
* proper vent sizing
* defective inducer motor
* restricted vent
* excessive wind
* low inducer voltage(115VAC)
* defective blower motor or capacitor
* defective pressure switch
* inadequate combusstion air supply
* disconnected or obstructed pressure tubing
If it opens after trial for ignition period, blower will come on for
90 sec. recycle delay.
Check your air filter for blockage, check pressure switch for a buildup of moisture. Make sure your inducer motor is turning and creating a vacuum to the pressure switch. Make sure all venting is clear and free of water or debris. Make sure there is no water in inducer motor and all drains are draining.
Posted on Jan 28, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Posted on Mar 14, 2010
Light pilot reset
If yours is a high-efficiency furnace, you should hear the stack blower start running when your thermostat calls for heat. Next, the igniter should start to glow and remain glowing until the thermocouple opens the gas valve and allows gas to flow to the main burner. The main burner lights and burns until sufficient heat is generated for the main blower to turn on and blow warm air through your house. If any action does not occur in the order described, repairs are in order.
Dec 08, 2013 | Kitchen Appliances - Others
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
I am trouble shooting a Bryant Hi-bred system that uses an air cooled heat pump with high efficiency gas furnace for backup and low ambient operation. How does the system decide whether to use the air...
Your t-stat should be set up so that the furnace is the second stage heat and also emergency heat. First stage (heat Pump comes on) sometimes they use Time to start 2nd stage, sometimes they use outdoor temp and this all bepends how bryant has set it up, without a model # I cannot tell you but send it and i will look in somebooks i have to tell you.
Mar 01, 2011 | Bryant Heating & Cooling
I turn on my furnace and the coil warms up and then the igniter comes on producing flame but only for about two seconds and then it goes out and the furnace just winds up blowing out cold air, after about...
It sounds like your blower motor is not firing up for some reason. This could be a circuit board issue or simply a dead blower motor. What is happening is that the system is basically sensing that the heat is not being "blown" to the rest of the house and it shuts it self off to prevent damage. After the flame comes on you should hear another motor come on. Also, most furnace's have whats called an error led that will blink when the system shuts off. Each blink represents a different error. You will probably get something about high heat limit reached.
Mar 01, 2011 | Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Our Armstron (magic Chief) oil furnace keeps shutting on and off during the heating cycle.
I will try to help, but a little more info would be great, when you say it shuts off, it is important to determine if it is the burner or the blower that is shutting off.
If the burner is shutting off and coming back on, the safety "fan and limit" control is getting to hot,,
If what I have listed above, there are several things that can cause it;
1. The first step is to make sure that the air filters are clean, the return air grills are clear, no objects covering them.
2. This part needs to be approached with care, Turning off power to the furnace is a must; then clean the blower area, and if it is a belt driven blower setup, inspect the belt, looking for cracks on the surface that makes contact with the pulleys. If the belt is old, it may be stretched and slipping on the pulleys, reducing the air that is being blown across the furnaces firebox, this will cause the furnaces safety "fan and limit" control to over heat and shut off till it cools off, then it will turn back on.
If the blower is the one that is shutting on and off, you would notice this at the supply registers in each room, air blows, then stops. This usually caused by really cold air blowing across the firebox, like after the house has been cold - over night, and usually will start operating more along the normal side of things as the home warms up.
Either the blower is moving to much air, blowing strongly in each room, or the furnace has been reducein it's firing rate - derated - a smaller nozzle being installed would be the main cause.... this is the first thing to check,,, if that doesn't do it, it would be highly recommended to have a experienced repair person look at it.
Remember when working in the blower area, please turn off the power to the furnace to save the fingers.
I hope this will give you a game plan.
Have a great evening.
Sincerely,
Paul Gibson
Mar 30, 2010 | Heating & Cooling
Central heat/air unit for home blows cold air
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
