Question about Car Audio & Video
Cant seem to find which wire from becker 1492 radio is for antenna extend signal
SOURCE: Red Lights
Check your microphone connection. There may be a short in your mic plug. Some radios require a microphone to be connected in order to receive. If you recently changed microphones, be certain it is wired for your particular radio. Hope this helps. Also, do not use radio if this condition still exists as damage will occur.
Posted on Nov 24, 2006
Benimur
  • 6966 Answers
SOURCE: Remote Control Extender from Radio Shack
To determine if your PC will simply not connect or if really your wireless AP/Router, please download NetStumbler, install and run. The software will determine if there is an AP within your immediate area (including yours/high signal strength), if there is & it is yours, then it is configuration problem, it none or some but weak (low signal/not yours) then it is a hardware problem and would most probably require replacement. Most of the time, the cost/time of repair would make the purchase of a new one more reasonable. If your Wireless Ap/Router was detected by NetStumbler, then perhaps what you need is to re-configure your system/set-up again.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
Posted on Nov 16, 2007
  • 20 Answers
SOURCE: Extending the Antenna wire to reach new deck
If it is a Chevy then the antenna wire will not fit in the first place. best buy sells an adapter that ill extend that wire and make it the right size. The wire is like 7 to 10 dollars.
Posted on Apr 14, 2008
emissionwiz
  • 79186 Answers
SOURCE: Electric Radio Antenna on 1994 Toyota Celica
Reverse the wires, one is hot going up and the other hot going down, the easiest way to deal with this is to just reverse them.
Posted on Nov 29, 2008
  • 272 Answers
SOURCE: Antenna motor runs while the radio is on or off. The antenna is stuck in the extended position. When the car is shut off the antenna motor continues to run to retract the antenna, but it doesn't go
You need to pull the fuse for the antenna or just unplug it. It has a fairly ridgid plastic wire that pushes the antenna up and down. Works fine until the wire breaks then it rolls up (antenna down) but it never increases resistance because the antenna never comes down , it's like a fishing reel when the lure breaks off, so the motor thinks that the antenna is still coming down and it will run and run and run trying to do it's job. Your lucky it stuck up and not down. If you want your antenna to go up and down again you'll have to buy and install a new one.
Posted on Jun 02, 2009
Please, I need radio code for Becker model BE 1492 s/n R1116431. pleeease
can you help me?
I bought a car but it hasn't code.
is a be 1492.
my car mb E300 td
Feb 18, 2013 | Car Audio & Video
I have a radio type BECKER model 1492, i would like to upgrade it to added a USB connection
Buy yourself a belsen for 35 euros from carrefour the one with no CD but a usb and sd card ,less chance of it being stolen
Jan 23, 2012 | Car Audio & Video
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
I need a code for a Becker Radio of my mercedes c220 94' with the following details: Model No BE 1492 Serial No. r1038146
You have to get it from the Dealers service dept. They call in the vehicle ID and Serial # of the radio to get the code, and they all charge for the service. Factory radio or aftermarket radio. Hope this helps
Dec 22, 2009 | Electronics - Others
Radio antitheft code needed
in your user manual there is a place where you will find code. Please carefully read your user manual .
Sep 13, 2009 | Car Audio & Video
Awful AM reception on Sony ICF-CD513 kitchen radio
You may have to use foil or other metal to extend the antenna artificially. I found years ago that even wrapping my hand around the end of it boosted the signal (though I'm sure you're not willing to listen to a radio while holding the antenna the whole time). I once sat a TV antenna on top of a portable CRT with its own internal ferrite antenna, and the video signal was about 80% there, audio 100%. This may be an inconvenient method, but it will guarantee at least most of the audio quality you want.
Jan 30, 2018 | Sony ICF-CD555TV 7 in. Portable Television
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Becker Radio Code
I need a code for a becker radio model #1492 ser# P1003590 can anyone help
Oct 22, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
