Question about Plumbing
Instruction manual for waterridge kitchen faucet Does anyone have the email that is sent containing the instruction manual for the waterridge kitchen faucet ; FPa4006cp
  • 148 Answers
SOURCE: need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
Posted on Jan 09, 2009
  • 49 Answers
SOURCE: I need o-rings for 529 fontaine NF-KPDS-ORB Kitchen faucet
try plumbing parts plus .
Posted on Mar 18, 2009
  • 297 Answers
SOURCE: American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
  • 349 Answers
SOURCE: Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
Posted on May 24, 2010
  • 5384 Answers
SOURCE: I need an instruction manual for a Moen Kitchen
Do you need the installation guide or the parts list? All of the documentation is available at Moen, see: http://www.moen.com/search/product-specifications?fromTradeResource=true&search_terms=7570CSL .
The direct links are: installlation/owner's guide: http://www.moen.com/shared/pdf/instruction_sheets/ins1912a.pdf .
The parts diagram is here: http://www.moen.com/shared/pdf/ca7570pt.pdf .
There are several finishes for the 7570 from Moen. The instructions apply to all. The parts list will give the specifics for the parts that depend on the finish.
I hope this helps.
Posted on Mar 08, 2011
I have a dripping WaterRidge NSF 61/9 . How do you fix this problem ?
On a water ridge kitchen faucet, there is a brass fitting that the water supply hose going to the faucet you pull out connects to under the sink, on that fitting youll find a small screw loosen it up, pull the fitting off , also loosen the other screw and disconnect the hose, now look inside the fitting there is some plastic junk ( not sure what its for) get a screw driver and a hammer and bash it out(not to hard) then put it back together. good to go, full pressure!! worked on mine and has for 2yrs.
Oct 25, 2017 | Computers & Internet
We have UPC kitchen faucet:WaterRidge NSF 61/9. plate is completely rotten,spray does not work. I think we are allegeable for faucet replacement because of life time warranty. sincerely, Yelena.
good luck with your "life" time warranty
contact the manufacturer if they are still in business and make a claim for a replacement or refund.
if it becomes too much of a hassle , junk it and get a n better make
Dec 28, 2016 | Plumbing
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Install danze kitchen faucet
Did u check there web site most have instruction manual if I could see it I could tell you more
Apr 18, 2014 | Danze Plumbing
Waterridge kitchen faucet pull out
Hello, I would recommend replacing the faucet.
Sep 28, 2013 | Plumbing
The single handle Delta kitchen faucet is very hard to swing back & forth. I was told by your company representaive that it needed O rings. The O rings have been sent to me, however no instructions...
remove the handle that turns water on and off , usually an allen wrench lift and swing back and forth at the same time. the spigot should come off. replace o rings lubricate with silicone grease reinstall spigot and handle
Oct 21, 2017 | Delta Faucet Plumbing
Hansgrohe faucet part-no. 92730000 faucet cartrige installation instructions
Please contact me at the below number or email and I can supply you with a copy of the installation instructions.
Regards,
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Nov 28, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Water Ridge Kitchen Facet with attached sprayer w...
You will ned to contact WaterRidge and have them send a Cartridge which you will have to replace. Their products are warrantied for life, so they should send it at no charge. The Customer Sevice # is 1-866-789-2273. You will need the Model # so they can send you the correct cartridge. I am trolling the web for replacement instructions, so I'll let you know if I find some.
May 21, 2010 | Plumbing
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
3,507 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
