Question about Intel D845GLLY Motherboard
Need drivers for intel(R) 845GllY
Hi
i need drivers for intel(R) 845GllY mother , i need direct setup files for easy installation.
  • arun_2003 Apr 08, 2009
    audio files and usb files are not working , mulitimedia audio drivers is missing
  • 77 Answers
What operating system are you using?
I have inserted a link for the most common drivers for WinXp Pro. If you need others let me know.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=829&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Chris
Posted on May 27, 2008
I NEED GGC 101 MOTHER BOARD DISC
search your motherboard driver installer and manual here
Aug 01, 2011 | Intel D101GGC Motherboard
I am not having mother board drivers
Hi Thanks for your question.
Please go to this website---> http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GAV
This website is Intel's download/support center. As you will see your motherboard is already chosen. What you need to do now id choose your operation system and download type.
Once you've done this your results should show underneath. Click on desired file and choose to save on PC when prompted. Once downloaded go to containing folder and lunch setup file. Installation should start at that point. Once installed restart your PC. Your drivers should be in place now. I hope this helped you. Please do not hesitate to ask more questions if this is needed. Thank you for using FixYa
Dec 12, 2010 | Intel D915GAV Motherboard
I Install the Intel 865 Dirver on Intel Orignal Motherboard but after sam time ialmnt5.cab file error and fault display settin
Hi.
I believe you are somehow receiving a Bluescreen sometimes. That happens when your Motherboard drivers are not compatible with the actual updates online.
1-Download Driver Genius.
2-So to solve this problem you need to click this link: http://www.intel.com/support/graphics/
and select the AUTOMATICALLY FIND GRAPHICS DRIVERS.
After the automated selection is done. Run Driver genius and Backup all your drivers. select a folder to keep your drivers. Next time you need to install your drivers it will be in the folder as a setup. you can rename your backup as MY INTEL DRIVERS just to remember.
3. Dont just accept updates from Internet, Disable automatic updates on your computer.
4. If you have an Antivirus - manually run antivirus updates daily.
Good luck hope you leave rating and suggestions if Information was Helpfull
Dec 01, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D865PERL sound driver not working
be obtained that the driver is not comfortable him, you will download a new installer again and type the following (Mother Board Model no #, Windows Supported) good luck
Jul 28, 2009 | Computers & Internet
PZ TELL ME ABOUT WHICH PROCESSOR(CLOCK SPEED) SUPPORT INTO 845GLLY MOTHER BOARD
845GLLY supported processors:
1.6GHz to 2.4 GHz Pentium 4 processors with system bus frequency of 400 MHz, for more information follow this link: http://support.intel.com/support/motherboards/desktop/d845glly/sb/cs-012859.htm
Apr 29, 2009 | Computers & Internet
Reg 845glly motherboard audio problems
restart, Press F2 for your bios setup screen.
Perhaps maybe the "integrated audio controller" option or similar is not enabled in the bios.
I know there's an option to enable/disable it ( on-board audio.)
Check to see if that's an issue or make sure this option is enabled in the bios. Then give a shout back.
So you've tried this driver already?
Try installer that and restarting your computer.
I hope this helps.
Jan 26, 2009 | Intel D845GLLY Motherboard
Mouse not working
turn of the computer then plug in the mouse then turn pc back on it should work
if not your mouse may be faulty.
Sep 11, 2008 | Logitech Wheel Mouse Optical
Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Jun 02, 2008 | Intel D845GLLY Motherboard
RAM installation
download express installation for bios update from http://www.updrivers.com/bios/Motherboard/Intel/12/176.html
put on one ram only in windows run your bios express installtion
file
Apr 13, 2008 | Intel D845GLLY Motherboard
Driver
Intel D915 onboard Audio, Video installation driver
Mar 07, 2008 | Intel D915GAV Motherboard
Intel D845GLLY Motherboard Logo
1,111 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
