Question about Alesis CD Twin LE - Portable CD Backup and Copy System Burner
I seems that on the reader side, the master cd of any type will slip- spin and make noises and not get up to speed. I will get a message "waiting on master disc". the writing side disc runs smoothly but the reader side slips and makes noisesand will not run. This happens on any brand of cd, and I can't get any to run without the message and locking up on the reader side.... Thanks
2 Suggested Answers
  • 37 Answers
SOURCE: Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Posted on Jun 24, 2009
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
I have a GMC 2003 Envoy, each time i drive it sounds like im speeding but im going really slow , i need to change the oil could this affect that and what do i do about the sound
Difficult to know what sounds like speeding: engine, road noise, what ?
If the oil change were to help, you have bad, bad engine problems. I suspect you may have a wheel bearing that may have failed. This makes a lot of road noise, alters with vehicle speed and NOT engine speed (drop to idle, noise the same).
There is a possibility of transmission slipping. this lets your engine speed up, but not actually move the car.
There is a third common issue and that is FAN. When your fan clutch fails, is locks up a normally free spinning (somewhat) fan, as if the vehicle needed max cooling... This noise follows engine speed, the vehicle seems to go just fine, but huge noise.... This sometimes is called Jeep fan noise, as many of those used to have direct drive fans.... If this is your case, the fan clutch gets replaced, not huge $, but more than it should be.
Nov 27, 2010 | 2003 GMC Envoy
Noise starts when spin cycle starts noise increases with rpm until reaches spin speed could there be a belt slipping or what??
Belt would squeel , bearings would chatter. try a bit of hard soap on belt. If it quites down the belt is slipping
Feb 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer functions, but rubbing noise during spins
The pump will make a sort of cyclic "creaking" noise just before it goes bad. You might want to remove the back panel and inspect the drive belt, make certain there are no knicks, loose pieces of rubber or it is slipping.
Let me know.
Regards,
Jul 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Ps2 - stops reading disc
there is a little wheel type thing that the cd sits on when it goes into the drive, the wheel makes the cd spin, these often wear out , after you play it for 27 mins the device heats up which causes it to slip , which would most likely be the noise that you can hear , it wont cost you much at all to get this fixed at a game console service store, if your sure the cd is still spinning after 27 mins , and making the noise , it is the laser cog slipping , in this case it is best to replace the whole laser section, which is one part , and if your handy at things like that i suggest you just go and buy the laser reader from a game console repair store , and swap it over your self , it is pritty simple to do ,
Nov 17, 2007 | Sony PlayStation 2 (PS2) Console
Alesis CD Twin LE - Portable CD Backup and Copy System Burner Logo
15 people viewed this question
Top Alesis Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
