Question about Garden
I would like to know how to open the reel up so I can feed new cord into my electric line trimmer as I have mis-placed my instruction manual for an ozito ltp-200 line trimmer. Thank you for your time
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 1214 Answers
SOURCE: open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Posted on Jan 15, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Is there a manual of
Hello there again i just wanted to know if you are done with the chat session we were having if so could you please give this session a rating for me so i can continue to help otherslike yourself
Best regards Mike
Posted on Dec 07, 2009
Testimonial: "This was a difficult subject and there apparently is not too much information available. I appreciate the effort. Mmorris"
rycgl
  • 1545 Answers
SOURCE: String will not feed on Homelite mod. UT21246. I
Maybe try replacing the faulty factory string head with a universal type head that you can purchase at Home Depot.
Posted on Oct 21, 2010
pctech1
  • 1940 Answers
SOURCE: I am trying to start
This engine is certified to operate on unleaded gasoline. Gasoline must be mixed with a good quality 2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1. Poulan/Weed Eaterr brand oil is recommended. (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). When mixing fuel follow the instructions printed on the container. Always read and follow the safety rules under FUEL SAFETY.
HOW TO STOP YOUR UNIT
To stop the engine, push and release the engine STOP switch. The switch will automatically return to the ON position. Wait 5 seconds before attempting to restart unit to allow switch to reset.
HOW TO START YOUR UNIT
WARNING: The trimmer head will turn while starting the engine. Avoid any contact with the muffler. A hot muffler can cause serious burns.
COLD ENGINE STARTING (or a warm engine after running out of fuel)
  1. Set unit on a flat surface.
  2. Slowly press the primer bulb 6 times.
  3. Move choke lever to FULL CHOKE position.
  4. Squeeze the throttle trigger fully and hold through all remaining steps.
  5. Pull starter rope handle sharply 6 times.
  6. Move choke lever to HALF CHOKE position.
  7. Pull starter rope handle no more than 6 pulls, until engine runs.
  8. Allow engine to run 10 seconds, then move choke lever to OFF CHOKE position.
STARTING A WARM ENGINE
  1. Move choke lever to OFF CHOKE position.
  2. Pull starter rope handle until engine runs. If engine does not start in 5 pulls, follow instructions in STARTING A COLD ENGINE.
Posted on Jun 03, 2011
Restring bolens bl150
There are two ways to re-string a weed trimmer.
  1. Wind new line on the inner reel
  2. Install a prewound inner reel
Check the owner's manual below for detailed instructions.
Bolens BL150 Manual
Mar 31, 2012 | Garden
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
May 15, 2010 | Toro& Electric String Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
