Question about Watches
I was wondering how to adjust the wrist ******** my Akribos XXIV Ak446bk "skeleton" watch. It has the stainless steel mesh bracelet and an unusual buckle system.
escapement
  • 2334 Answers
SOURCE: How do I shorten watch bracelet?
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 21, 2009
bongkito
  • 344 Answers
SOURCE: Cannot turn off or reset
Good Day!
Please mention the make and model of your wrist watch.
Posted on Jul 24, 2011
SOURCE: tessot steel wrist watch band
i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
Posted on Jul 13, 2008
dmbgo
  • 58 Answers
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
Posted on Jun 22, 2009
SOURCE: Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
Perhaps this replica watch and strap would fit. It's $295
http://www.salesreplicawatch.com/Tag_Heuer_6000_Series_Mens_Watch_WH1153.BD0678.html
Posted on Aug 26, 2009
Just recently purchased and received watch. how do i unclasp?
press the two lugs together, that are sticking out to release
Jan 11, 2016 | Akribos Xxiv Womens Dazzling Diamond...
I bought it from Marka VIP site, and it's not working pls. advice urgently .
contact the supplier and ask for a return / refund as the item is not functional as described for the sale.
if the unit is a digital unit make sure that you have activated the battery by removing the small block under the knob ( crown) and pressing it back into the watch
May 18, 2015 | Akribos XXIV Saturnos Skeleton Automatic...
Online manual for Akribos XXIV
this video will show you
Sep 22, 2014 | Watches
Extra link 823a
This person wasn't asking for advice about buying a rubber wrist strap for a diving watch, but rather was asking about where to get an extra link for the watches stainless steel bracelet1
Jun 12, 2012 | Breitling Aeromarine Colt Auto / Colt...
My Akribos XXIV Men's Large Dial Diamond Quartz Chronograph Bracelet Watch wirst is dangling the screww that connects the face & band came out & i can not locate im trying to gain info where to...
Most makers have a limited warranty and does not cover anything outside the case.
Have you tried any of the local watch repairers; on the face of it, it sounds to me that a watch repairer should be able to fix it for you.
May 19, 2011 | Watches
I bought an Akribos Shutter Watch, and it will tick for a while but after 2 hours or so, it will stop.
It needs a service.
The watch needs to be cleaned internally.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Akribos XXIV Saturnos Skeleton Automatic...
Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
Sep 23, 2017 | Omega Seamaster 2541.80 Wrist Watch
Watches Logo
2,031 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
