Question about Philips 50PP9202 50" Rear Projection Television
Rear projection i have a wierd red rainbow at bottom of screen. convergence not fixing.
    Sergeant:
    Champion:
  • 346 Answers
Check or replace convergence ic exact duplicate
Posted on May 27, 2008
Sony Red green rainbow bottom tv screen rear projection AND LIGHT PICTURE
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 08, 2013 | Sony KP-51HW40 51" Rear Projection...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
KP-51H1w40 has red blue lines curved across the screen about an inch or so apart, like a rainbow
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Jan 09, 2010 | Sony KP-51HW40 51" Rear Projection...
The screen has a rainbow of red blue and green on bottom
The specs say this is a CRT type projection system, so it could be related to the display or to the TV. Since this has an SD card, it might be good to plug in the memory card with some pictures on it, and see if the problem persists with a source other than the tuner. That might at least narrow down whether you have a display failure/adjustment issue or something else.
Jul 04, 2009 | Panasonic PT-56TWD63 56 in. Rear...
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Zenith rear projection tv 56"
You have a convergence problem. Go to the convergence menu or consult the owners manual on the convergence procedure and try to correct i if you can.. However if the red image is bowed and or not linear you will probably need to call a technician to repair your set. Most likely the red convergence output chip has failed. This is a common problem with all CRT ( picture tube) rear projectors. Good Luck. Happy Easter
Mar 23, 2008 | Zenith R56W36 56" Rear Projection...
51mp392h/17
HAVE RED BOW . BLUE IS GOOD . RED I CANT AJUST JOESTV2003@YAHOO.COM
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 50PP9202 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
