Question about GE Profile JT980SKSS Electric Double Oven
I am having trouble with my GE JT980 trivection double oven, which is about 4 years old. About 3 weeks ago while preheating both ovens it tripped the 40A breaker in my electric panel. This seemed odd but I reset the breaker and it worked fine and I had used it a few times since without issue. However yesterday while preheating both ovens it tripped the breaker again and this time when I try to reset it just trips again immediately. Even though the ovens, obviously, should not be on after I reset it the house lights dim slightly as if there is an actual surge of current being drawn when I close the breaker so I don’t think it is a bad breaker. I suppose it could be a short in wiring otherwise it seems like it would have to be a short in one of the power boards to cause a 40A surge as soon as the breaker is closed. I’d appreciate if this is a failure anyone has seen before or any suggestions for likely root cause or trouble shooting (in particular is there anything I can try before pulling it completely out of the wall, which I’m sure will be a bear of a job).
  • neals Oct 09, 2010
    Well, I pulled it out tonight and, sure enough, the problem was in the junction box. The installer used improper connectors (Ideal 454 wire nuts) to join the copper oven wires to the aluminum house wires. One of these overheated, melted and shorted to the box. I'm surprised it worked again for a while after the first time the breaker tripped a few weeks ago. The short to the box must have been intermittent. The good news is that it should be an easy and inexpensive fix...
textonor
  • 130 Answers
SOURCE: Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
Monogramman you have described where your issue is. When you dismount the front panel you are moving the wires. If I was looking at your unit and you told me that it worked with the panel removed, I would look at the wiring between the front panel and the relay board for a loose connection. You should be able to pull the connectors ( remember to shut off the power for safety) and put a flash light on the backside of the connector. Look thru the front an you should see very little light. If you see a lot of light there is your loose connection. Or if you are careful, you can wiggle the connectors until you get to one that is causing the clicking. Hope this helps. I doubt if it is the oven thermistor as the oven heats while the front panel is dropped down.
Posted on Jan 06, 2008
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
  • 10 Answers
SOURCE: JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Jul 18, 2009
I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
Jul 09, 2010 | Ovens
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
After self cleaning can't get "locked" signal to clear.
disconnect power from wall and wait 30 min,and try again
Jul 04, 2009 | GE Profile JT980 Electric Double Oven
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
Replacing Bake Element for JT980SK3SS (GE Trivection)
Thank you.
I found it without putting the 3 in the search.
All the screws appear to be 1/4 inch hex head screws.
Feb 25, 2009 | GE JRS06SKSS Electric Single Oven
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
GE Profile JT980SKSS Electric Double Oven Logo
189 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
