Question about Dell Inspiron 9300 PC Notebook
I have a dell inspirion a while back ithe sound stop working i notice that the jack for head phones hole is pushed in broken off or something inside does anyone know how to fix it about how much would that repair be
  • 3,940 Answers
Audio ports are part of the motherboard
Motherboards run about $100
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=inspiron+9300+motherboard&_sacat=See-All-Categories
Posted on Oct 04, 2010
How do i ajust the hand brake 2006 territory tx
Hi Johan
jack up the the side you want to work on,now look at the back of the wheel on the dust plate there is or should be a small grommet or rubber bung on the plate, remove this bung and using a torch look inside you should see something that looks like a small cog or gear its a bit awkward to see inside as its a small hole, using a flat head screw driver insert it into the hole where the cog is making sure to get it into the teeth of the cog and push down on the screw driver handle this should rotate the cog and adjust the brake shoes inside the drum, spin the wheel now and then to make sure it is not grabbing if you over adjust it, it will stop the wheel spinning freely, you need to get it so there is a slight drag on the wheel as you spin it, once you have this rotate it in the opposite direction once and that should be perfect for you, and just do the same with the other side.
NOTE if you find nothing is happening, try rotating it in the opposite direction until it starts to grab you will notice this when you spin the wheel.
Hope that help
Jan 05, 2015 | Ford Territory Cars & Trucks
How to repair the head phone jack of laptop d510
hashmi903,
To fix the head phone jack on a system you would need to replace the sound card or the motherboard where the headphone jack is soldered onto the board. You could send it back to Dell for repairs or contact your local computer repair shop for repairs.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 11, 2013 | Dell Latitude D510 Notebook Computer for...
Head phone jack faulty
hashmi903,
Thank You,
Dell-Jesse L
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
Dell inspirion 1501 laptop, not charging battery light showing red, have bought a new mains adaptor but still not charging
Does the back dc jack seem loose when you have the ac adapter plugged into it? Wiggle the cord right where it plugs into the laptop. If it moves around then most likely the dc jack on the inside has one of it's 3 points of contact broken. This means that someone would need to re-solder that contact or put a whole new jack into the laptop. Another thing to try is replacing the battery. Sometimes they won't charge because they are bad. Another thing to try is take the battery out, plug it into the adapter, turn it on, get into windows, shut down, put battery back in, turn on. See if that resets the battery and makes it charge.
Apr 30, 2010 | Dell Computers & Internet
I need to repair internal wires
Typically you have to unstring the guitar to get access to the insides.
Use a small miirror to view the insides. You may need to drag the jack out of the sound hole to resolder wires if they are broken. There should be three wires on the jack. One carries the audio, one the ground, and the third connects the battery when the instrument cable is plugged in.
After re-soldering the connections if needed, procure a piece of 1/4 inch wood dowel from your hardware store. Push the dowel through the hole where the jack goes and near the sound hole. Push the jack onto the dowel and then pull it back through the jack hole and pass the nut over the dowel and onto the jack threads and tighten. The extract the dowel rod from the jack.
It is near impossible to reach clear into the guitar body to put the jack back in without the dowel rod unless you have very tiny arms.
Feb 09, 2010 | CF Martin Music
Headphone Jack Stopped working
It's worth a shot, is there a pan control somewhere in the settings? These settings act as a cross fade between the right and left stereo signal. If its on all the way left or all the way right, you won't get sound out of one phone. Also have you tried to use a different pair of phones? The only other thing it could be is if there are internal volume/gain controls. My iPod has these. It limits the max volume I can get out of it. It may have been turned on some how. If it's not any of those, then i'm afraid you have a faulty headphone jack. It may be need to be sent in for warranty, or repair. If this is the case, you could in the mean time fanagle it a bit... Sometimes if you pull a phone out of the jack just a touch it creates a short in the jack which sends the single thru as mono. Hope that helps.
Feb 10, 2009 | Archos Internet Media Tablet MP3 Player
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Dell Inspiron 9300 PC Notebook Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
