Question about Casio Exilim EX-V7 Digital Camera
Dock charger My batteries won't charge. When I put camera in dock using ac , no lights show on dock. When I hook dock thru computer, no lights show also. Does this mean the dock is not working? I bought the cameraa about 6 months ago. Is the dock still under warranty?Thank you, Alan
  • Anonymous Jul 15, 2008
    I'm also having this issue, the charger worked a week ago and all of a sudden it doesn't work.
    R
  • Master Girl Aug 21, 2008
    Casio EX-S2 dock not working to charge my camera. The USB light is working. Please tell me if there is somewhere that I can buy a charger cradle.
Although I have no solution to this problem, my camera appears to be doing the same thing. Please let me know if you find a solution!
Jackson
Posted on Jun 18, 2008
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Vivicam 5340s camera dock
You can't charge the camera with the USB cord because the camera dosn't have a charger built inside. You need to use an external charger. Here is a link showing several sites that have battery chargers for this camera.
Dec 26, 2008 | Vivitar ViviCam 5340s Digital Camera
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
Ccd-trv37 trouble with recharging battery
I think, battery is not being charged in camera.
  1. Plug the charger in AC out let.
  2. hook up with camera, check camera wroks with charger,
  3. set camera power button in OFF / Standby position,
  4. attach battery to camera and check any Charge-Light lit?
  5. If yes, leave it on charge up to 4-5 hours for new battery.
Aug 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
When I put camera on docking it win,t show charge
First, the dock will charge only the batteries that came with the device; not other rechargeable batteries.
Be sure that the Kodak battery is inserted correctly, the door is closed securely, and that the camera is securely seated in the dock with the power cord secure to both the dock and the AC outlet. The USB cord does not supply power to the dock.
Hope this helps.
DigiChick
Jun 09, 2008 | Kodak EasyShare CX7330 Digital Camera
Casio Exilim EX-V7 Digital Camera Logo
80 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
