Question about Dell Inspiron 1501 Notebook
My laptop got soaking wet from a storm we had and it wont turn on is there a way to check the circuts to find out which is bad
    Guru:
  • 1,082 Answers
You need to let it dry out for many days, think 10-20 days, then try to power it on. You probably have destroyed it but it is worth the wait.
Jim
Posted on Oct 04, 2010
Brake lights wont work unless turn signal is on
Wild guess, crossed wires, bad printed circut film connector in tail lights, bad ground connection to the same film. Otherwise, wiring problems up front. signial/ break circuts.
Mar 04, 2015 | 1999 GMC Jimmy
I got my lumia soaking wet in a storm how do I get it going again?
Er. idk. BUT i once dropped my phone in a bucket of water,
and my gf fixed it somehow.
... idk, what she did but it is POSSIBLE to fix it..
GL
Aug 21, 2014 | Nokia Lumia 920
P2422
P2422 - Evaporative Emission System Vent Valve Stuck Closed
This valve is likely mounted next to the vacuum canister and got full of water. Refer to undhood emission stciker for location of valve and canister.
Aug 29, 2012 | 2005 Hyundai Santa Fe
Ok replaced the intake manifold , car wont start, checked crank sensor, checked plugs and wires. fuses, fuel injectors ,engnition sensor bad , replaced it coil packs good and still wont start .getting...
or you getting the right fuel pressure? check fluid filter, check pressure regulator, check spark plugs to see if they are soaking wet if they or wet take them all out and pull fuel pump relay out turn engine over and blow all gas out the plug holes. install plugs and relay and try start again , check engine compression, check coolant senor ,check cam sensor
Jul 06, 2011 | 1999 Pontiac Grand Prix
My motherboard get wet
Do not turn on your laptop or it will fry the components.It must be disasembled to dry it off.This is a serious issue that can result in a very costly repair.Have a tech.take it apart to clean all the internall parts.
Good Luck.
Nov 10, 2009 | Acer Aspire 4315 Notebook
My washer is not spinning when it goes into drain mode. The cloths comes out soaking wet. What is my problem
the first thing I would check if the pump is clogged. it also wont spin if the door doesnt lock. other then that the only thing left is the speed control board is bad
Nov 04, 2009 | Kenmore 43142 Front Load Washer
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
Pantech matrix got wet wont charge
your battery is probably bad. take out the battery and plug it up and try to turn it on without the battery in. if it works just replace the battery. if not then your phone is fried.
Jul 14, 2009 | Pantech Matrix Cell Phone
Dryer wont dry my clothes
Your heating element is not working. The element could be burnt out or the high temperature switch is bad.
May 29, 2009 | Dryers
Dell Inspiron 1501 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
