Question about LG DLE2301 Electric Dryer
The dryer is new and its not drying at all. also ths cooling system light is on?
  • 489 Answers
Usually the reason is the exhaust vent in the wall leading to the outside of the house is heavily restricted with lint or other debris. Pull the exhaust vent out of the wall and run the dryer to see if the load dries normally. If it does, you will need someone to clear out the exhaust vent to resolve the drying issue.
The cooling light is a display that tells you what will be happening during the cycle. When it flashes, the dryer is in the cooling mode and is continuing its operation but with no heat. That usually lasts about 10 to 15 minutes.
Good lucj
Posted on Oct 04, 2010
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
The dryer is taking a lot longer to dry now than before. I'm sure it's not lint, insufficient gas supply or the vent needing cleaned. The cooling light is staying on solid and the drying light...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 06, 2011 | LG DLG2524 Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
I have hotpoint consdenser dryer model ctd00p - not drying clothe
if the water tank is empty you probably need a new thermostats .
Feb 11, 2010 | Dryers
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
LG DLE2301 Electric Dryer Logo
206 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
