Question about Sony KV-32XBR450 32" TV
Sony KV-32XBR45 Problem
TV takes 2 minutes to warm up such that the CRT turns on. Audio begins immediately.
Screen has very green tint -- color is not right and looks washed out.
I have isolated the long turn on delay to the board that attaches to the neck of the CRT (which I shall call the "CRT board"). Hitting it with circuit cooler spray when the TV is off and it takes longer to turn on CRT. I also did the reverse. This morning, I used a hair dryer to heat the board and it came on much faster than if I had not done that. I'm convinced that (at least) the long turn on time is definitely tied to this board.
I'm not sure if this also is associated with the green/washed out look.
I cooled the three 3-pin ICs and they do not appear to be part of the problem.
Any suggestions?
Also, any idea where I can buy a replacement CRT board? The numbers printed on the board are:
1-646-720-23 (on bottom of board) and CMKS-81X (on bottom of board).
Thanks,
Speakout
  • speakout May 28, 2008
    How does one adjust the white balance on this particular TV? I don't have schematics.
    Thanks,
    Speakout
    We're getting close. The software and Sony jig notwithstanding, what is the actual component that is adjusted to achieve white balance? A var resistor? If so, where might it be located? I do not have access to the software and jig, but perhaps tweeking the pot may get me close. (Otherwise, this TV is headed to the dumpster. I view this as a last-ditch attempt to resurrect this TV and feel I have nothing to lose if the adjustment can't be made successfully.)
    Thanks again.
  • 10,594 Answers
Hello Speakout,
You do not need that board. You can resolve this problem by adjusting White-Balance. (greenish picture tone)
I think you have enough technical knowledge how to adjust white balance of this TV.
Posted on May 27, 2008
  • Shahid Electronics
    Shahid Electronics May 28, 2008
    It can be adjusted by software in tv, requires a Sony designed jig controled and connected with PC to access the tv software.
    Shahid Electronics May 29, 2008
    Alright, On CRT board, you will see a Var-Resistor named G2, try to adjust it.
    if this Var-Resistor not there, then its located at Fly-Back Transformer (hight voltage area) there you will see 2 controls, one is for Focus and other called G2. hope this info will usefull.
Color problem
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KV-LX34M80 34" TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
It is hard to say. Kind'a like the sound of a light saber on stars wars is turned on but faster and ends loudly and abruptly. It takes just under 1 second.
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony Trinitron KV-32XBR37
This may be a bad crt or picture tube. Take a good look at the picture when it's on and see if it has a pinkish or greenish tint. This is easiest to see if you turn the color adjustment all the way down. If it looks like the tint is green or pink and the focus isn't great then it's probably a bad crt. Not worth repairing if its the tube.
Jan 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Sony KV-32XBR450 32" TV Logo
339 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
