Question about Fisher and Paykel WA37T26G Top Load Washer
My fisher and paykel washing machine is not starting a cycle as it is not getting any water. The pipes are turned on and is properly connected. It results in service light(spanner icon) flashing with a beep sound every second. Can anyone help?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine beeps do any lights light up to indicate an error code?You have mentioned the spanner shows up but do any others light up as the machine is beeping?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Oct 04, 2010
My fisher & paykel washing machine MW612 is not draining the water out it stops as the rinse cycle. How do I get to the pump please
Hi you will have to take the machine out and remove the mains cable plus the water pipes don't forget the waste pipe will be full of water its possible that the waste pipe is blocked so therefore cannot get rid of the access water enabling it to go to the next step or there are debris in the pump stopping it turning or the motor has died due to it having not being able to turn I hope its the less expensive one cheers eric
Nov 16, 2017 | Fisher Washing Machines
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Dishwasher drawer not draining water.... F1 error... Drawer is holding water......possible hard water build-up...
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
May 05, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a fisher & paykel ecosmart washer no water
Please make sure that your water supply lines are properly connected and turned on. Also, there are typically small filters at the end of the hoses where they connect to the washer. Check those and clean them if necessary. Since the hoses will be disconnected at that time, flush the lines by running the water into a nearby drain or bucket.
Hope this helps! Rate my solution!
Jan 05, 2010 | Washing Machines
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not drain water out properly
you may need to take the pump apart as it may be clogged.
Apr 09, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel WA37T26G Top Load Washer Logo
208 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
