Question about Toys
I have an exersaucer from 1999 and i can not figure out how to put the seat insert for child to sit in on
    Sergeant:
  • 168 Answers
In this site, check in INSTRUCTIONAL MANUALS section.
I hope this helps; remember to rate this answer.
Posted on Oct 04, 2010
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
How do i put the seat back on my evenflo exersaucer
There are several models of exersaucers, but hopefully the seat attachments are similar. Here is a video from Evenflo showing how to assemble the product. This might help you.
http://www.evenflo.com/resource.aspx?id=467&rcid=19
Sep 29, 2010 | Evenflo Exersaucer Triple Fun Active...
Whats the proper height when using the exersaucer evenflo
  • Place the product on level ground and make sure the legs are the same height. (The tray should be level.) That's the best way to avoid tip-overs.
  • Follow the manufacturer's age, weight, and height recommendations and keep the owner's manual for future reference. Don't use the activity center before your baby can sit up unassisted, and stop using it when your baby reaches the height or weight maximum and can walk or even stand up by himself, which means that he could easily tip it. And, as a general rule, if your child can tip over the activity center by just leaning over the edge or can climb out of it, it's time to retire it.
  • hope this helps.
  • Aug 04, 2010 | Evenflo ExerSaucer SmartSteps Active...
    How to put the cloth seat back on
    This may not be the one you have but this site will advise you how to get model and manufacture date so that you can get exact instuctions.
    Jul 05, 2010 | Evenflo Exersaucer Triple Fun Active...
    Reattach seat to Evenflo Exersaucer
    Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
    Feb 07, 2010 | Evenflo Baby Gear
    Need to put seat back on old evenflo exersaucer-no instructions
    there should be small plastic clips on the material for the seat and then you just clip them to the plastic..... it sounds much easier then it is
    Jun 05, 2009 | Toys
    I need to know how to put the seat in an Evenflo Exersaucer Deluxe because we received it that someone didn't need it anymore. Its an older on from 95. Please can someone help me because my granddaughter...
    https://plweb.evenflo.com/faq_detail.aspx?faqid=3934
    Question: How do I put the seat pad on the Exersaucer? spacer.gif Answer: 1.Line up the red diamond on the seat pad warning label with the triangle on the back of the seat ring. 2.Fit the elastic loops through the quarter inch gap between the seat ring and rotating rings and hook the elastic loops over the prongs on the bottom of the rotating ring. 3.The plastic tabs on the seat pad are only for reinforcement and don't hook to anything, but should be threaded between the 2 plastic rings. If you still need further assistance please refer to the instruction sheet or call the Evenflo ParentLink Consumer Resource Center at (800) 233-5921 or (937)773-3971 for further information.
    Mar 25, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
    I need assembly directions for evenflo exersaucer triple fun.
    1. Remove toys and seat from the exersaucer.
    2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
    3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
    4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
    5. Turn tray (C) upside down and remove both end caps (E) from beneath.
    6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
    8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
    9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
    10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
    Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
    I have a older exersaucer made by evenflo and i dont know how to put the seat back on
    original instructions for any exersaucer
    https://plweb.evenflo.com/ShowDocument.aspx?ManualID=234
    25702569.pdf
    Sep 10, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
    Exersaucer seat
    Evenflo - Exersaucer Instructions
    25702569.pdf
    Dec 30, 2007 | Evenflo Baby Gear
    Toys Logo
    91 people viewed this question
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Toy Expert? Answer questions, earn points and help others
